100W Ultimate Fidelity Amplifier
Reactions: priyank
Follow-up on Apex A9 amplifier
Dear all,
Here is a short (and probably final) follow-up on my posts # 12984 and 12986 in this enormous thread. I have now put my homemade Apex Audio A9 amplifier PC boards with power supply in a (recycled) cabinet (19", steel). The power supply lines run at ± 37V. I have not modified mr. Slavkovic's schematic in any way, with a reduction of the series resistors for the Z15 zeners as the only exception (see post 12984). The amp really sounds great, it sings! (as is said on the Russian Komitart site). However, I disagree with one statement made by our Russian friends - they mention that quiescent current through the power MOSFets should be set to 15 mA. In my ears, this is not correct, Iq should be set to 30 mA or a bit higher (as was also said by Mr Slavkovic). Purity of the sound is much better at the higher quiescent current, and the heatsinks don't even become lukewarm. Anyhow, this project can be strongly recommended.
My amp is a dual mono setup (each channel has its own toroid power transformer and power supply) although both channels are combined in a single cabinet. Imaging is very good.
Best regards,
arensattic
(aka Aren van Waarde)
Нету дорожки 47к - BC550
I checked and I actually used a modified version of the above layout. I really just simplified a little as Alex had designed it with two different sets of holes for the resistors and caps. I removed the extra holes to make it easier to etch and drill. I am adding those file here.
These are also for toner transfer. I you need photo sense files let me know.
Hi Indian members,
i have about 20-30 pcbs of attached apex preamp and psu which i want to get rid of.
only shipping and packing charges of inr 200. payment by g-pay. interested members can contact me via pm with qty required and postal address.
i have used it over a year and works well. no support for build will be provided. All values provided on sch and also on pcb..
regards
prasi
Добрый день всем участникам сайта . Кто бы мог предоставить информацию по Apex AX30 , есть ли у кого плата АХ30 (PCB)
:cop: English only please. Rules.
Good afternoon to all the participants of the site. Who could provide information on apex AX30, whether anyone has an AH30 fee (PCB)
Hi Indian members,
regards
prasi
Oh!, i forgot to explicitly mention that pcbs are free. only shipping and handling of INR 200. within India only.
Reactions: priyank
thanks i build circuit but there is a problem
without input signal and no speaker connected and no heatsink and just +/-45v supply i adjust 0.33ohm resistor voltage about 10mv but it begin rising continuously and go over 20mv and 2sc5200/2sa1943 become warm and if i didn't disconnet psu become hot.
is that normal or something is wrong in circuit?
