Best Compression Drivers today 2022?
How flat from say 500 to 10kHZ, is the DCM50....are there any significant peaks or suck-out's that need DSP to correct? ..I realize that this is also waveguide/horn specific, but generally speaking was wondering if one needs to correct for anomalies between 500 and 10k...
https://josephcrowe.com/blogs/news/b-c-dcx50-coaxial-compression-driver
https://www.dibirama.it/component/c...ver-2-8-ohm-160-wmax.html?catid=22&Itemid=580
https://bcspeakers.com/en/products/hf-driver/archive/2/8/DCM50
Significant peaks and suck-out's are typically resonances which your DSP can't correct. Only the transducer design or modifications can.
It can only amplify or decrease the resonances in amplitude etc.
Overlay graphs and compare for an idea.
Dibirama measures with and without horn. What is visible in the impedance/phase graphs in both is also a indicator.
Should also be some more measurements around.
Compare it to a old midrange compression driver like for exampme what i adde below, and make own conclusions based on your priorities.
https://josephcrowe.com/blogs/news/yamaha-ja6681b-compression-driver
i don't have that peak at 1.5Khz with my 240HZ Tratrix horn just the little peak at 10Khz but i cut it before and have a tweeter so in my config the DCM50 is pretty flat +_2db from 450 to 8khz the only think that can make me change for a coaxial DCX50 or DCM464 is to have a point source even as it is difficult to match a 55cm diam Horn with a external tweeter..
Reactions: Arez
Have been lurking here for a while and decided to make a 3-way with the Beyma CP755ND Al with the Ciare PR614 horn.
Will cross it somewhere around 800-1000Hz.
As woofer i will start with the Faital 15PR400 in a PPD subwoofer housing (ppd is an ripole like housing, but should be better). I am using that woofer allready in an open baffle speaker. I will see hoe it performs. Not easy to find an upgrade for that woofer. It will do the lows till around 100Hz.
And inbetween i am going for a 10" 18 sound 10NMBA520 on a open baffle in the 100-1000Hz range.
This will be powered bij Hypex Fusion 503 amps with dsp.
It will be used in a home audio situation.
I am following @milezone
Recomendations on a the CD driver and horn. Thanks for your work and effort to test so many drivers!
I do wonder if the larger horn can integrate well with the somewhat smaller mid i have in mind.
I am aware of the directivity issues that can happen. But i cant seem to find a way to figure that out...
Can someone eleborate on that?
Reactions: Bas Horneman
Using the Ciare PR614 myself. Fantastic horn!
