An A1 descendant - a relentless analysis
You know what. I think the design is more the result of marketing. The performance was never the 1st priority.
Here I am pretending the marketing person.
What sells? Not a class-D amp with 0.006% thd for sure.
1. It has to be symmetry. A good looking circuitry must make better sound. Right?
2. No miller compensation. "Globle Negative Feedback", and "Miller Cap" are 2 forbidden phrases from HIFI.
3. Specs? It measures better than a McIntosh MC275. It doesn't matter!
Reactions: hbtaudio
@wahab
The designer was:
Great Grandmaster Tim de Paravincini ...
We need more current, Iq approx 1.25Adc.
This amp is basicaly a differential driving a high current VAS, the OS is a transimpedance stage and as such has a high output impedance, so with a 8R load the OLG is 46dB and with a 80R load it logicaly increase by 20dB at 66dB and 83dB with a 800R load.
And no amount of current will change this characteristic, the amp is badly designed and that s all, he should have
used something like this instead and even if not fantastics he would had got much better numbers.
Edit : i add the comparison between the original schematic, in red the original MFA1 and in green
the much simpler schematic in this post, level is 10.5V pk/8R, bias currents are 1.08A for the original
and 0.7A for the one in this post.
Reactions: hbtaudio
Distorsion of this schematic should be huge, beside MFA1 has never been a good design, and never will be,
it s well below other such symmetrical diferentials that were published roughly 40 years ago.
I had an A1, and while it sounded O.K on small speakers, the sonics were not to my liking. It’s shortcomings were obvious when it was used on higher-end speakers and studio monitors, where it’s “sound” dominated the playback.
In reflection, I kind of feel the class-A part was hoopla that generated waste heat doing little, except imitating a George Foreman grill. It did not have the detail, airy treble or wide stereo separation I would have expected based on the reviews, and deep bass was non-existent. It was a quick sale when I’d had enough of it.
I wish the OP luck and hope it turns out better than the original design.
Realworld spectrum:
Dear Bernhard,
as usual, I don't understand your answer - with the best will in the world I can't make sense of it.
However, we can play a little bit with the resistance values of the original - and possibly get a better A1, or a more reliable candidate?!
HBt.
Psst
this thing sounds like an oily fried dough ball dripped with honey.
On the contrary, I don't know what a fat dripping sponge cake dipped in honey sounds like, but if a transfer were possible, which of course it isn't, then you're completely wrong!
On second thoughts it could do some good as home guitar amp, this would eventualy fit a Gibson 335/345,
but for HiFi purposes it s perfectly inadequate unless it is used as a tutorial to display what is to be avoided.
Now you're really putting the beautiful Musical Fidelity A1 down. Which at 20 peak watts has just an THD1k = 0.03%, see posting #47 (G+18,5dB).
Should we now be sad for Heinz L., the CEO of MF?
HBt.
Attached an example from the link in my above post.
The spectrum very well correlates with the sound representation of the amp.
Translation of the honeyball: The sound is overly warm, sweet and oily.
I had more than one A1 and I know what I´m talking about.
