Choctaw - 10 Watt Amplifier, 1 Opamp + 2 MOSFET
Zoltan, what are your sonic impressions till now ? Can it handle 4 ohm speakers ?
Everyone has different taste, it's very subjective
Personally I don't like audiphile poetry ;-)
I like it and I'm happy that I built this little amplifier
But as always - the whole system and room acoustics play It's different for everyone
I don't have 4 Ohm speakers
I think it should be fine as long as you take care of a large heat sink and a suitable transformer
Thanks, do you have suggestions about the heatsink and optimal transformer ?
I built the amplifier according to the values recommended by minek123 so we have 400mA of quiescent current for each transistor. The power supply voltage is 16.9V so we have some heat to dissipate.
I just used a lot of things I already had
I used a recycled heat sink - from an old Denon amplifier (170 x 40 x 80mm) It's warm but not hot
I think you can calculate what heat sink we need.
I also have a transformer from an old project. Mine is 225VA.
I know it's too much but it works fine
I think a 2x12V 80VA -100VA transformer should be enough.
We won't be playing at full power all the time 🙂
10W per channel is really a lot. For everyday use, 2-3W is enough.
Reactions: j4n3zz
Thanks STV for the links.
I am affraid those other two design would not meet my expected distorsion and noise figures.
That is why I am interrested in this design. Are there simulated noise and distorsion data for the other two designs?
Line up, can I use OPA1611(can it deliver enough output current?)? What will be the phase margin?
Can I bridge the design with balanced signal in? And what will be the expected output power?
Sorry for the questions, you guys are great simulators and I can build and measure great stuff.
