DIY biamp 6-24 crossover
why don't you try the 6-24AXO with the 50kOhm - trimpots (at the input-buffers) recommended by Nelson Pass?
I was going to do this, but the project was taking me so long I figured why not go straight to the fancy pots. I'm in no hurry.
Guess I was wondering if/when I decide to swap out the pots, if I could get away with dropping one on each channel for lower cost. I'm assuming there will always be at least one pot per channel set on 0Ω rendering it useless? Unless there is another reason I'm missing?
The only thing as a beginner I can think of is if the input voltage is somehow too high for the amplifier. For the foreseeable future I'll be feeding it 2VRMS max i think.
@Ramblr you have a very nice looking build. I do have one concern about your chassis grounding scheme. Unless I am missing a wire in the photo you posted, it looks like you only connected the screen of the transformer to the safety ground on the IEC connector. The chassis should be directly bonded to the safety ground so if a wire falls off or a transformer fails the chassis will be kept at ground potential.
Isn't the schematic missing this connection? I hope it didn't propagate to the PCBs.
That connection is NOT present on the PCB. If one selects a third order filter, the calculation must include the superfluous resistor and pot values. It is also possible to short the resistor and/or pot, but then the flexibility of eventually selecting fourth order is compromised. I did it and it's not difficult to revert to stock. I wonder if this was an error, or was simply impossible to implement in the board layout, which is already a marvel of design.
You are correct I did not ground the chassis. I will fix my oversight. Thank you pointing out my mistake, as a new builder its much appreciated.
What kind of power supply is that? Regulated?
It is from Antek. Look under their power supply section. Transformer and rectifier in one package. Non regulated. My thought was is it has to be better than a wall wart. Is the power supply section of the board not enough? Should I build a super regulator board to add to it? I know enough to be dangerous as can be seen in my missing chassis ground.
I've been trying to track down strange sounds from the right channel high pass section of my crossover (posts 1,203 and 1,560). At first I thought it was the jfets; replaced them all. Problem not solved.
It turns out that four of the biasing resistors were the wrong value (100 ohm instead of 68 ohm). I stupidly didn't check them before installing (since they came matched to the jfets, I didn't know what value they should be, and the bands were all the same). And by an incredible coincidence they all ended up in the same section of the board (the offending channel). They're now replaced. However I now have a new problem. Out of the circuit they measure 68 ohm. Once installed, two of them still measure 68 ohm; but the other two measure only 50ohm. I take them out: 68 ohm. I put them back in: 50 ohm. They're at the position shown in the attached photo.
Why would this happen? Every other biasing resistor on the board measures 68 ohm. And is this a problem? Just to be sure I replaced the two jfets they were biasing, but that didn't change anything.
Could the board itself be faulty?
Any help gratefully received!
