DIY Class A/B Amp The "Wolverine" build thread
hey! can i make a castoum wolverine board, which has just 2 transistors instead of 3 or 4? i dont need that much power, and ya know, to make stuff cheaper. i assume i will have to rework the output stage board, but the ips? what about it?
Just use a EF3-3 board and install 2 output pairs. It will work just fine at low output levels but I question the practicality of it as each output transistors is about $3 USD
Fired up the second channel today to dial in bias and offset.
With my scope i saw the following output. The frequency seems to be just about 50kHz which means it must be the Cobra S2. I am however a bit surprised that the noise exhibits an amplitude of nearly 300mV. Is this normal with a SMPS? The input is shorted at the terminal, and my scope is connected directly to the board, so i don't think it should be due to bad wiring. 🤔
Hi Ponti17,
This Kindle of signaler is just usual when measuring at the output of an smps or on a circuit fédéral from it: if as I understand this is with the probe tip shorted, this is then pure common mode noise current -which the score translate into diff mode- that you are seing.
Also: measurements should be made over 50 ohms impédance and the ground wire of the probe removed and replaced by a wire as short as possible directly attached to the probe groupe ring. Otherwise, what the score displays is Just crap....
Hope this helps.
Kal
Hi Ponti17,
Hope this helps.
Kal
Thanks a lot! I still find instrumentation quite difficult sometimes, and your response is a big help 🙂
This may be of interest to builders and designers - Digikey now has a listing for 2SC4793 and 2SA1837 's by EVVOSEMI
Might be worth one of the well-equipped team members to grab and test a couple compared with the Toshibas?
The spec sheet doesnt mention a Cob and the speed looks low.
Reactions: asuslover
After fixing my burnt Zobel network, i assembled one channel again today.
After slowly adjusting bias and offset i decided to connect my scope, DAC and test speaker.
Unfortunately the channel is quite noisy. What i believe to be 50Hz noise is very audible from the speaker 🙁
I have a feeling that it might be due to bad wiring. Could one of you guys in here maybe confirm if my wiring scheme is bad?
Thanks a lot!
Can I ask which Micro Audio Cobra smps you are using. I can really benefit from your wiring schema as I have a modded S1. Good luck with the noise.
Do you want to send me a couple to measure ?
