Do "cooling holes" around a tube really make sense?
I´ve seen some rather utopic modern tube amp designs having heatsinks on tubes; not a good idea as tube envelopes made from soda glass doesn´t like unequal thermal metallic contact, which can cause localized cracking. This occurred on an amp with EL84 tubes. As for tube pins; a dead end issue as the Kovar base pins have same thermal coefficients as the glass itself. All this stuff has been worked out now 100 years ago.
Bench baron
Some serious heatsinks for GU-50: https://www.diyaudio.com/community/threads/gu-50-with-heatsink.379486/post-6849793
when looking at 300B builds, some use holes around the socket of the tube and some do not.
The argument made is that these holes will produce air flow around the tube in some "chimney effect". I am sceptical that this has any significant effect, especially if the case is closed at the bottom, but even if not.
Are there any real measurements available that prove the chimney assumption?
Also, the tube has a heater / filament to, well, heat it. So, given a design with some room around it and a grill/mesh above / around it at max, is it even desired to cool it?
By my personal experience, for a 300B in reasonable Class A operation (plate supply voltage < or = to 400VDC), you do not necessarily need venting holes at the base, since that large bulb tube doesn't heat too much...
On my U-300B below :
You can see that there's a chimney provided around the socket of the 300B :
But finally, I drilled no hole nor installed any fan cooling under the chassis, so it's just a vent without chimney effect, so in fact no air circulation !
Conversely, on my U-OTL, where 3x 6080 operates in Class AB1, there's a chimney and fan cooling system :
You can see the chimneys around the 6080 sockets :
And the little fan at the back of the amp, with 3-speed settings : Hi/Mid/Low, the Mid speed being already enough and is inaudible :
I measured the temperature of a 6080 top bulb, cooling off, after 5 miniutes of operation : 190°C, that's much more than for a 300B...
So yes, in this case, a chimney plus light fan cooling is indeed welcome ! At LO speed, the chassis at the base of the tube stays lukewarm, and at Mid speed, it remains cold.
T
Reactions: mz543578854
Man, that layout is what I lack in experience. That photo is revealing in how something should be approached. Damned human eye picks up too much in cases such as this and yet ignores stuff like motorcycles and pedestrians.
So this is trying to say it can cause harm?
In much wisdom is much grief: and he that increaseth knowledge increaseth sorrow.😉
Why would the air flow through the holes or the slot underneath the tube if no pressure difference is present?
Air is not heated under the tube's envelope by the tube or does it? Funnel or chimney is yet another story...
Hotter air will rise, even from a warm chassis top (due to internal heat dissipation transferring to the chassis). Any aperture on the top of the chassis (holes or valve base openings), along with apertures for cooler air entry (eg. underneath) will achieve some airflow induced by hotter internal temp within the chassis.
I'd suggest that just the act of ventilating the chassis internals is important to minimise temp rise of all parts entombed within. It's pretty easy to poke a thermometer of K-type into a chassis and measure the internal temp both with and without apertures. The inherent reliability of any internal part will benefit long-term.
The hottest portion of an output stage valve's glass is broadside to the plate, and that is where highest level of convection to air will occur. There is typically a lot of distance between chassis top and the hottest portion of valve glass, which would allow air to come in from local ambient, especially for valves located along an edge of the chassis, or where valves are separated by substantial distances. Some datasheets indicate minimum separation distance advice, as well as orientation of plate structure so that radiation is improved by not pointing directly at the anode structure of an adjacent valve. Similar to inherent part reliability within the chassis, there are long-term benefits to a valve from operating in a 'cooler' environment, especially related to lower glass temperature and consequential lower outgassing.
Not sure what that quote has to do with physics.
There is gonna be heat inside the chassis, some of the tube's heat goes through the pins into the socket, there are resistors inside which by design create heat. The air outside the amp is cooler than the inside of the chassis, hot air is lighter so will rise if there is a way for cooler air to displace this hotter air from below. Seems pretty obvious to me that air is gonna move and if you simply seal the chassis, the heat will be trapped inside. It also seems to me that if this air is moving past the much hotter tube, that's probably not a bad thing. And that this rising hot air off the tube might help pull air through the amp chassis.
Another example of this, my computer router has no fan to create a pressure differential, just slots in the bottom and the top. I can hold my hand a few inches over the top of it and feel the heat rising from it, that's some sort of magic huh?
Err, no. The original slant of the question was with respect to the potential benefit to the power tubes, not to the internal components, so the correct comparison would be holes around the bases of the tubes versus holes away from the tube bases.
kind regards
Marek
Reactions: Ixnay
