DIY Class A Headphone Amp suggestion
Ok, 2-3 hours and its done. Working from first power on. So far positive, sound is very promising. Negative, small click when you plug and unplug headphones since its cap coupled.
Will work on it.
Powered by 24VDC, using well regulated variable supply +/_12 VDC. It runs hot, but not too hot. May lower final power supply slightly.
Nice sound so far. No measurements done, may do quick distortion test later. Volume at 1/3 is terribly loud, yet still clean, so plenty of power with 220/100 ohm resistors already. It would be cooking at 43/20 ohms.
(What about 3-5 watt version?)
I did not make pcb right now, its from other project (mic pre). Just had to improvize a little with some wires, as it was 3 transistor circuit. I already improvised on this pcb with hamptone circuit.
So far i used jvc gummies and ess headphones (came free with big ess heil tweeter). Have not tried any better headphones yet. I got many. I got pretty good sennheiser and hifiman, but that will have to wait till in box.
Ok, here we go...
I connected my measurements laptop, its not perfect, but it will do. I measured at 878mVpkpk, or 315mVRMS, which is as loud as one could tolerate with sennheiser hd580 headphones. So i did not measure with pure resistor or open (10k res). Real use measurements.
Good news, bad news. Its output is flat, but there is rollof. Why? Distortion is nice, mostly second harmonic, but its higher than predicted.
Background noise is below 100dB, its quiet.
I'm currently working on a headphone amplifier that may be of interest to some, It is a little more complex but worth it.
It's a strange all in phase design with a single transistor handling both feedback and voltage gain, It's still on the bench being tweaked but distortion will certainly be less than 0.01% just before clipping. Though very low distortion was not the end goal for this project.
It's more aimed at low-impedance phones as the output will be 4V less than the rail voltage, but could always be ran at a higher voltage to compensate.
I like experimenting and trying something different and non conventional things, I've listened to it as it is now and sounds very dynamic and clean. A great start.
It should be later on today I will report the schematic and some FFT's 🙂
Reactions: passive420
