As Vunce mentioned output current is +/-1mA. This is similar to AD1862. Value of the IV resistor depends on your tube stage and the output level you are aiming for. Look at designs tagged in post #1 or even better, look for the boards designed by Michelag, since it has been proven to work nice.I am planning on using the AD1865 with tube out put,what value should the I/V resistor be?
Is it 4mA the DAC outputs?
I read in the datasheet that is has an internal I/V converter is it a good idea to use it instead?
You can try reducing that 100R, let's say to 75R and see if it sounds better. I think that even 50R should not be a problem. Normally you will have a lower voltage at the output.100ohm you're good to go with my (well, grunf's) tube output stage. Look back, I uploaded a Gerber (I think I'm going update it since I forgot the pads for screws, otherwise it remains the same) and the schematic with it's PSU.
It is by far the best sounding piece (but with ad1862) that I ever built.
At 50ohms I would definitely choose a tube with twice the mu.Normally you will have a lower voltage at the output.
In that case, we could already talk about grounded grid circuits, especially if the tube has an amplification factor greater than 50.
The problem with ECC88 and 50R could only be in a worse signal-to-noise ratio.
Not only in THD, but also that the AD1862 sees a lower impedance at its current output (ideally it would be 0R).Yes, difference is in cents of thd %
This is why grounded grid circuits are better but they also have their drawbacks.
For me in that case the best is Ei 6HM5 with amplification greater than 70 times and the input impedance is below 10R. EC86 would also be a good choice, but I've never tried it.
That would be great! I have a few ECC88 type tubes that are not being used. What a great community.I think I'm going update it since I forgot the pads for screws, otherwise it remains the same
You really don't need 2vrms on output with a preamp in line, unless you want to drive amp directly (which is still too much if you use class D monsters). Lower load on iout will always be better. Since this is diy, really just look at your own system and how much gain you actually need, and apply accordingly.
Thanks for the information. I have ordered some of the SMD AD1865. Much less expensive than the DIP version so I'll skip the group purchase for now.AD1865R SOIC is much cheaper and easier to find.
View attachment 1337937 View attachment 1337938
@Legend Electronics is a solid vendor, excellent packing and quick shipping for AD1865R chips.
@grunf Is this the circuit you used? For C1, 1000uf... what type of cap do you use?Not only in THD, but also that the AD1862 sees a lower impedance at its current output (ideally it would be 0R).
Would the D3A in triode mode (mu 70) be good enough for the grounded grid circuit?
Not 0R or you can not convert curent into voltage, no?. Let say fw m Ohms at least.
D3A, I was said you need at least to match both and it is candidate to oscillation if you take not great cares.
Input at cathodes are said to sound not as good as grid with I/V, no ? Am I wrong ?
Can anyone confirm these chips have not been used already requiring them to be desoldered from previous install?Thanks for the information. I have ordered some of the SMD AD1865. Much less expensive than the DIP version so I'll skip the group purchase for now.
by the hell, why going with ad1865 when having better chips like the ad1862, tda1541a or pcm 56/58, pcm 1702, ????
The only advantage of a standalone chip is imho to make it starground routing,not classical plain ground layer seen from a EMC/EMI point of view, am I wrong ?
that's the old version for my DAC, here's the new one for AD1862@grunf Is this the circuit you used? For C1, 1000uf... what type of cap do you use?
For C3(C1) put two UES1E102MHM in parallel with a good polypropylene cap.
I'm not sure that D3A is a good idea for a grounded grid, it's easier to do it with EC86,6S4P,6HM5... or even ECC88.
I'll know when I receive them - and report back.Can anyone confirm these chips have not been used already requiring them to be desoldered from previous install?
They are AD1865R 28pin SOIC package, brand new. Good to go. You need adapters to fit the 24pin DIP footprint however.
@zoom777 waiting for Mouser order so I can build up the DAC boards.
Why not try them? Cheap and easy to find. Easy to use - only 5V supplies. Some people I trust say it's worth a listen, so is the PCM58 apparently. AD1865 is in the ranking as best multibit DAC.
20bit vs 18bit 😉 If I can I will try the lot, Miro has essentially developed a platform to plug in different DACs. PCM1704 is the hardest to find as legit for a sensible price.
Did you not like the 1865?
Also Andrea Ciuffoli liked it very much - seems to suit a tube stage?
https://www.audiodesignguide.com/DacEnd/index.html
- Digital Line Level
- DAC AD1862: Almost THT, I2S input, NOS, R-2R
