Acoustic Horn Design – The Easy Way (Ath4)
A big tip for co-entrant style multiple-entry horns;
The holes will f*ck up the hf response badly because of all the internal reflections.
This can be solved for a very large part by covering the mid-holes with an acoustic mesh (like a gore acoustic vent https://www.gore.com/products/gore-acoustic-vents-industrial-applications) with just about the right acoustic resistance (use the lumped part of abec to test this) to be "open" for the mid frequencies while being "closed " for the HF.
The membrane should be reactive, not resistive (meaning not porous)
hint; even a bit of painters masking tape could work..
As I understand the acoustic vent mentioned is ePTFE, that is microporous PTFE. Searching for this, there are ePTFE or sintered PTFE films from other manufacturers as well, but to be able to buy some of it seems rather hopeless to me right now.
There's also PTFE coated glass fiber fabric in porous versions, I'm extrapolating here from the basic idea that there should be a PTFE surface to reflect high frequencies, but it should be also breathable to some extent to let sound through, IF that's the basic idea.
Or maybe Teflon coated breathable fabric that is used for outdoor gear, but can't really imagine what a piece of fabric covering the mid outlet would do. Like, wouldn't it want to move as a second membrane? Same with painters masking tape. On similar note for something that would seem like a closed surface to the eye, there's also PVC coated polyester fabric, I guess breathability could depend on the thickness of the plastic coating, light coating being not airtight?
First try with a Selenium D3300Ti, originally a 2" driver, here made effectively a 1.3" (which is the phase plug exit).
The original mounting flange can be removed and a Gen2 adapter easily made.
It's not bad at all, I actually quite like the results, for a 3" diaphragm.
View attachment 1333185View attachment 1333186
View attachment 1333192 View attachment 1333207 View attachment 1333193
Interesting you post this now. I have a pair of Beyma 750ti that I have been thinking about doing this with. I was going to ask about this here but see incredibly little done with 2" compression drivers.
Is there a particular reason you tried this 2" driver or did you have it lying around?
1.5" 18Sound ND4015Ti2, 4" diaphragm.
A520G2, basic 1.5" adapter.
Found out there are filter membrane discs available on Amazon for pretty low cost, from PTFE, nylon, paper, with specified pore sizes, like 0.45um 0.22um. I guess nylon might be more interesting as it's a stronger material. If anyone happens to have a hole in his WG and wants to try to patch it and see what it does. (Also there are lots of different types of Whatman paper filters, specified thickness, air flow rate. My first guess would be that thick/stiffer is better.)
This article mentions the usage of Nomex fabric in a large scale acoustic installation to reflect higher frequencies https://fabricarchitecturemag.com/2012/05/24/hearing-fabric-2/
Reactions: Psytron
