DIY Class A/B Amp The "Wolverine" build thread
Hi everyone, just wanted to drop in, introduce myself and say thanks for the amazing info throughout this thread. It’s impressive how much time and effort has been put into this design by everyone here.
I’ll be joining in and building up a pair of EF3-4 boards from the 3rd group buy. At the moment, I’m just reading, learning and gathering components. Hopefully I can contribute something useful to the thread in the future!
Looks Like R7 & R8 on the input board are set up for SMD or resistors. Reviewing photos of past builds, I don't see any that chose to use SMD. Is there a reason for that? The SMD parts offer 0.1% tolerance vs. 1% for the resistors. Does that not make a difference for these parts?
Thanks. I haven't found a really good photo of a completed underside of the IPS board, but the few I've found don't show the J1 jumper installed to the TMC.
Just confirming that it is still necessary.
2nd GB May 2024 for your boards Chiptech. Has some updated bias notes.
Andy right, the MELF part listed on the 4th GB BOMs is currently a bit small.
There's also an ancient error on the 1st GB BOM that's probably not going to affect anyone, but the 1% Mica part listed for C5 for MJE drivers is the larger CD19 series which has larger lead spacing. The correct fitting part is CD15FD471FO3F
yes thats 0204 not 0207, 0204 wont fit latest version of the PCB those pads were changed.
Thanks for the heads up on that. I'll look into it. I did recently see there was a discrepancy between the bom and the pcb. I have been talking with Harry to look into it. I had a quick look at the pcb and don't see any reason why a small footprint can be used or why it was changed. Maybe the one from R3,4 was copied into the position of R7, 8.
