swak,
I have no experience with any other TOKIN devices or the Schaded mosfets.
I would tend to think all TOKIN devices would have far more in common than differences. Zen Mod, who has extensive experience with both approaches, says the Schade Mosfet (which i assume is what you are calling a simulated SIT) is different more than less good.
I know I like the idea of the choke loading of TDV and the MOFO amplifiers. I have found, in my case, having the choke by itself in the circuit without any additional resistance makes for a better amplifier. I got lucky in my case - I also am not obsessed with all four amplifiers having the same dissipation.
I am using MEH speakers with efficient drivers but after active EQ much of that sensitivity is erased since no one wants a broad 10 dB rise in the midrange. Whatever the speaker I think having as much power as possible is better than trying to get by with a few watts. As you surmise no crossover components between the amplifier and the speakers - each driver has its own TDV.
Rahul's designs are easy to assemble but do require tweaking of components which has the advantage of one getting to know the amplifier on an intimate basis.
Thanks El Arte! I’m no Pa, just a nice student looking for an ‘atta-boy’
Here's a new schematic with JFETs. This is an LTSpice schematic, not a PCB schematic. So there will likely be revisions to current and voltage setpoints and maybe some component values based on actual devices and parameter spread. I have ordered large quantities of JFETs to test what the spread is, especially for the J111. If you are interested in revising your existing preamp, it can be done. Read on.
The key revisions and rationale are as follows:
1. JFET input and gain device. I am showing a J74 here for the input, but J175 is likely to be the final choice.
2. J111 has a high pinch-off voltage. This has two benefits: first, it allows operation of the input device in its linear range and second, it allows a large swing while staying mostly linear. It can swing 50V with <0.5% THD with mostly second harmonic.
The upshot of all this is that it sounds relaxed with a feeling of headroom.
3. The cap and pot below R2 are gone. This can be implemented in the existing PCBs by taking out the bypass coupling cap and shorting across the cap pads (C102byp).
4. The JFETs are rated at about 400 mW. So, the J111 drain voltage should be limited to about 40V to keep dissipation under control. That means we can bring down the supply voltage to 80V. Okay, this is lower than earlier, but the sound is so much cleaner at higher swings due to the devices and new operating points.
5. The output impedance is somewhat high and so it won't drive really low input impedances well, something like 10k in the next stage is okay. For the PCB, I am working on a JFET buffer.
Why does this sound better? I spent a LOT of time (lot for an amateur, anyway) listening to various device combinations. JFETs are simply more linear in the current range we want compared to other devices. They generate lower amounts of higher order harmonics and provide more headroom (when correctly designed). There are some combination of devices in this design that produce lower THD, but when subjected to large swings, they don't sound as good as JFETs.
Next steps is to test device spread for J111s and J175s and then commit to a PCB. I am not making any promises of when I will be done with the PCB. But I am done with the circuit and device testing. If you have an existing PCB, you can replace the gain and input devices, short C102byp, and adjust setpoints to get most of the way there.
THF51 can simply do much higher power than the 2SJ28, but if you have horn speakers, then 2SJ28 is fine in terms of power. But hey, what's stopping you from building two amplifiers and listen for yourself?Thanks for your comment too, I will keep an eye on the next refinement of the SCG, and perhaps build one just for fun. You mention you are using the THF51. How would you compare them to 2SJ28 or even simulated SITs?
I have tried that and the sound was... flat. It looks good in the simulation but did not sound better to me. Did you do any listening with it? What were your impressions?@ra7 Have you tried to connect Rsch1 to the source of Q103 instead of the drain of Q101?
I played with the same kind of circuit ( https://www.diyaudio.com/community/...es-from-a-n-channel-dmos-and-not-only.376683/ ) inspired by the UNSET and that was a solution to have real CCS load on the "solid-state-triode", otherwise it will see the CCS in parallel with the 11k load.
Then a dedicated load can be set to fix the loadline of the "solid-state-triode", so its harmonic content.
Another option would be to not triodize the gain device, which could be done with JFETs coz they so linear. And then apply feedback from the output to the input to control gain. I tried that but unfortunately it was not stable on my build with wires going long distances. But it could be tested on a PCB with short distances.
A third idea, which I also tried, is to put the LND150 in the input position and use it like a traditional cascode but with the triode top device. LND150 is a gem of a device because it has a very wide Vgs base. It results in not much gain but a wide input capability (the all important headroom). It sounds quite good with the J111 on top and produces >40 db gain (with 10X from the top device). It can swing huge amounts of voltage and you could have the voltage gain for the entire system sorted from this one gain stage. Amazing. But, JFET follower input just sounded better to me in my system where 20 db gain from this stage is enough. Still, this is worth a try and I really want to use LND150 somewhere in the future.
Bravo!
Take your time, I am totally broke and unemployed.
I preferred the resistor loaded for its warmth or the ccs with the feedback taken from the output as mentioned above. The buffered output version per se is not good sounding, but was the driver for a dc coupled, inductor loaded SE amp I’ve never built.Did you do any listening with it? What were your impressions?
I had a PP tube amp with this configuration for the phase splitter, but I didn’t like it so much.
If you have 2sj74s would they be a better choice? Or is there something about j175 besides cost and availability?
I should also mention that the J74s need to be selected for an Idss >10 mA. And operated at a Vgs of 0V to 0.25V. The J175 and J111 have much higher Idss so you don’t run into the Vgs being >0 for them.If you have 2sj74s would they be a better choice? Or is there something about j175 besides cost and availability?
Tried the lower voltage - went to choke input to bring down the raw supply to 90 volts and set zener to 81 volts - 6.5 volts at the two sources - 78 volts going into the current source - just gave it a try and it does not work here.
Lost 3 dB of gain and gained massive amounts of second order distortion - rose at one point to 350 percent.
I had been using 124 volts before the current source and all worked very very well.
Going back. I must be misunderstanding something.
If you change the supply voltage, the drain voltage has to be reset. Once that is done, it should work the same.
Having had no problems with 124 volts I went back and will leave it there. I am using little heatsinks on the TO92 cases.
How does one adjust the drain voltage? Is that by selection of devices? With the voltage I am using I have found the devices to be non-critical.
Do you hear a sonic advantage to using the lower voltage? If you do I will have to make the change!
THANKS, ra7
THANKS, ra7
So on the drain of Q11 you have 90V, on its source you have 78V.How does one adjust the drain voltage?
Ref. this schematic: https://www.diyaudio.com/community/attachments/sch_v3-1_onechannel-jpg.1134690/
Consider Q101 as a triode, so on its drain you should point around 40V, adjusting RV103 (so indirectly its source voltage) to reach it.
Now most probably you have a too high Q101 source voltage, so the "triode" working point is too much on the right of the VI plot.
IME if you talk about the raw PSU, just less dissipation. If you talk about the working point of the "triode", it's just a matter of tastes.Do you hear a sonic advantage to using the lower voltage?
Different working point and feedback ratios give different ratios and phases of harmonics.
Rick, just adjust the voltage on the gate of the input jfet till you get 40V on the drain of the middle jfet. The source of the voltage is the main supply and so when that is reduced gate voltage goes down and so does the drain voltage.
Rahul, do you hear an advantage to using the lower B+ or was it mainly just to use a lower voltage?
Obviously, my B+ voltage choice comes from the transistor version for the Schade device. When you went to the FETs there was not a recommendation to lower the voltage so I have left it as it was.
I get a good second & third harmonics ratio through the loudspeaker measured with REW. The devices do not seem to be protesting in any way.
I would not mind the lower voltage which would bring along a choke input supply versus CLC - just curious to hear if that would make any difference to the sound.
On the other hand the things sound so damned good as is I hestitate to mess around with them!
For those without the official PCB the circuit is easy to assemble on perf board. I hear no faults with this circuit. This is a gift from a gifted fellow. Give it a try.
Other than saving energy and reducing heat dissipation, there is no reason for a lower supply. So, if you have it set up already, let it be.
Ordered the new PCB today. Must be tested before calling it final. I created a 'hat' option, which I am planning to use for testing. The hat has just the main circuit, keeping the input switching, power, and volume control the same.
The PS is on a separate PCB. It is a standalone PS that can be used for many things.
- Schade Common Gate (SCG) Preamp
