Vacuum Tube SPICE Models
Hi Jan
You asked me what the contact voltage is.
This is a voltage caused by different materials used for different electrodes. It is typically 0.55V or so, for sure less than a volt.
It offsets the triode's Plate current curves, in same manner as there would be a voltage source connected between the grid pin and the actual grid.
To get your measurement fitted, I had to tune the contact voltage to a very unusual high value. So I suppose there's something wrong...
BR Adrian
PS: I will send you the (most probably not accurate due to this issue) spice model code in a private message, ok?
I have got intrigued by using triode part of EM84 for audio purposes to see how it behaves. I cannot find EM84 plate characteristic, datasheets show just length of column plotted depending on grid voltage. I am aware there are commercial devices but I do not want to invest into them. It surely could be possible to do it old fashioned way as in the fundamental course p.44.
In order to spare myself the effort I was wondering if someone already made the measurements or better yet has the model available to share.
6G2P SPICE Model
Code:
**** 6G2P ******************************************
* Created on 03/02/2024 20:18 using paint_kit.jar 3.1
* www.dmitrynizh.com/tubeparams_image.htm
* Plate Curves image file:
* Data source link:
.SUBCKT 6G2P 1 2 3 ; Plate Grid Cathode
+ PARAMS: CCG=4.2P  CGP=2P CCP=3.4P RGI=2000
+ MU=95.8 KG1=2179.33 KP=676 KVB=439.29 VCT=0.424 EX=1.355
* Vp_MAX=400 Ip_MAX=5 Vg_step=0.5 Vg_start=0 Vg_count=8
* Rp=9560 Vg_ac=54.45 P_max=0.5 Vg_qui=-72.48 Vp_qui=300
* X_MIN=63 Y_MIN=187 X_SIZE=757 Y_SIZE=376 FSZ_X=1260 FSZ_Y=630 XYGrid=true
* showLoadLine=n showIp=y isDHT=n isPP=n isAsymPP=n showDissipLimit=y
* showIg1=n gridLevel2=n isInputSnapped=n
* XYProjections=n harmonicPlot=n dissipPlot=n
E1 7 0 VALUE={V(1,3)/KP*LOG(1+EXP(KP*(1/MU+(VCT+V(2,3))/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G  ; TO AVOID FLOATING NODES
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G   ; TO AVOID FLOATING NODES
C1 2 3 {CCG} ; CATHODE-GRID
C2 2 1 {CGP} ; GRID=PLATE
C3 1 3 {CCP} ; CATHODE-PLATE
D3 5 3 DX ; POSITIVE GRID CURRENT
R1 2 5 {RGI} ; POSITIVE GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
@Khron, I am not the modelling expert, but here is 6Z2P aka 6AS6, I hope it helps you
*Triode 6Z2P, 6AS6 03.2024 acamus
.subckt 6Z2P 1 2 3
xU1 1 2 3 Triode Cak=0.035p Cga=2.5p Cgk= 4.1p Kg1=656 ex=2.95 mu=32 kp=100 kvb=50 vgc=2 Rgk=2k
.ends
*vacuum tube triode model
*K - cathode
*A - Anode
*G - Grid
.subckt Triode A G K
C1 A G {Cga}
C2 G K {Cgk}
B1 A K I=(pow(v(e1),ex)/kg1)*(v(e1)+abs(V(e1)))/V(e1)
C3 A K {Cak}
D1 G K DGK
B2 e1 0 V=(V(a,k)/Kp)Log(1+exp(Kp(1/mu+(v(g,k)+vgc)/sqrt(kvb+pow(V(a,k),2)))))
.model DGK D(Vfwd=0 Ron={RGK} Roff=100meg)
.ends
Reactions: Khron
I have found the model here, just reposting with asy file
EM84.sub
  • EM84 Indicator Tube Spice Model
  • Author: Zabb Csaba
  • Date : 10/1/2021
  • The following parameters are not modelled:
  • (1) Filament and filament warmup time
  • (2) Limiting values
  • This model is valid for the following tubes (within max. ratings):
  • 6FG6, EM85E, 6FG5 EM84 6E2 6E3P
.SUBCKT EM84 K G A L D
X1 1 G K EM84x
V1 A 1 DC 0
H1 4 2 V1 54k
E1 D K Value{IF{V(4,K)>0,V(4),0}}
V2 2 K DC -3.21
G1 L1 K A K 4.36u
R1 L1 K 299k
D1 L L1 DMOD
R2 D K 1MEG
.MODEL DMOD D
.ENDS
.SUBCKT EM84x P G K
+ PARAMS: Mu=57.99996 Ex=1.421792 Kg1=997.5376 Kp=62.31465 Kvb=9849.735
E1 1 0 Value={V(P,K)/Kp*Log(1+Exp(Kp*(1/Mu+(V(G,K)-2.33)/Sqrt(Kvb+V(P,K)*V(P,K)))))}
G1 P K Value={(Pwr(V(1),Ex)+Pwrs(V(1),Ex))/Kg1}
Rcp 2 K 4.3MEG
D1 P 2 DMOD
Bg G K I=(URAMP(V(G,K)+5.95E-1)^1.5)*1.15E-5
.MODEL DMOD D
.Ends
EM84.asy
Version 4
SymbolType CELL
LINE Normal 48 -16 48 0
LINE Normal -48 -16 -48 0
LINE Normal 20 0 12 0
LINE Normal -12 0 -20 0
LINE Normal -28 0 -36 0
LINE Normal 24 12 -24 12
LINE Normal 32 48 32 20
LINE Normal 24 12 32 20
LINE Normal -24 12 -32 20
LINE Normal 28 16 -28 16
LINE Normal -15 -17 -29 -17
LINE Normal -15 -13 -29 -13
LINE Normal -15 -17 -15 -13
LINE Normal -29 -17 -29 -13
LINE Normal 16 -80 16 -48
LINE Normal 23 -48 9 -48
LINE Normal 23 -44 9 -44
LINE Normal 23 -48 23 -44
LINE Normal 9 -48 9 -44
LINE Normal 64 -32 32 -32
LINE Normal 32 -25 32 -39
LINE Normal 28 -25 28 -39
LINE Normal 32 -25 28 -25
LINE Normal 32 -39 28 -39
LINE Normal 36 0 28 0
LINE Normal 40 5 36 0
LINE Normal 40 16 28 16
LINE Normal 40 5 40 16
LINE Normal -32 -32 -32 -64
LINE Normal -22 -32 -32 -32
LINE Normal -22 -17 -22 -32
LINE Normal -48 0 -36 0
ARC Normal 48 -64 -48 32 48 -16 -48 -16
ARC Normal 48 -48 -48 48 -48 0 48 0
WINDOW 0 -8 -80 Right 2
WINDOW 3 24 64 Right 2
SYMATTR Value EM84
SYMATTR Prefix X
SYMATTR Description 6FG5 EM84 6E2 6E3P
SYMATTR ModelFile EM84.sub
SYMATTR SpiceModel EM84
PIN 16 -80 NONE 0
PINATTR PinName L
PINATTR SpiceOrder 4
PIN -48 0 NONE 0
PINATTR PinName G
PINATTR SpiceOrder 2
PIN 32 48 NONE 0
PINATTR PinName K
PINATTR SpiceOrder 1
PIN -32 -64 NONE 0
PINATTR PinName A
PINATTR SpiceOrder 3
PIN 64 -32 NONE 0
PINATTR PinName D
PINATTR SpiceOrder 5
Courtesy of jazbo8 the Ayumi SPICE model library:
Files included, copyrighted material, if you distribute these files make sure that the first three lines are not removed.
PSpice Models => View attachment 638558
A time-saver, the file below contains all the Ayumi SPICE models that are compatible with LTspice - manual editing of the files is no longer required!
LTspice Models => View attachment 689353 (New 06/29/2018)
This is great -- thanks -- works fine for SIMETRIX
useful for comparing distortion of tube circuits to transistor tube emulation circuit equivalents . Grid leak effect is an important area to emulate
Uh-oh, your help exposes my lack of spice knowledge. How do I edit all the text in that file so that I can either put it into the folder I keep the specific .asc file in or use it as a spice directive on the open asc ?
I know there are other ways but use spice so infrequently I'd have to start from the beginning again to learn how to use them and then forget again before the next time.
As you say, there is more than one way to manage a collection of models but I prefer to put all of my tube models into one library file (Tube.lib). You can also have separate libraries for different tube types, like triodes in one file and pentodes/tetrodes in another. Any way that makes sense to you is the "right" way. 🙂 Once you have created a library file, you just attach it to the .asc schematic using the .lib or .inc directive. You can also include individual model files this way, using the .inc directive.
If you do create a library file for tubes, you need a naming scheme in case you have more than one model for the same tube. I have several models for most tubes so that I can verify that a circuit behaves more or less the same with different models. My naming scheme uses a suffix, like 12AX7_AN for the Ayumi Nakabayashi model and 12AX7_NK for Norman Koren model. The only edit you might need to make to the actual model file is on the .SUBCKT line, which defines the model name in SPICE. You can't have two models with the same .SUBCKT name or LTspice will complain about duplicate models.
As you suggest, an alternate approach is to place the entire text of the model file on the .asc schematic itself. I might do this for a model that I don't use often enough to include in my library file. In this case, just make sure that the instance name of the tube on the schematic matches the .SUBCKT name.
Maybe this will get you started.
