6.3VAC to 6.3VDC LDO supplies MIC5156 based tube amp upgrade
https://www.diyaudio.com/community/...56-based-tube-amp-upgrade.382265/post-7515640
This post has virtually all the values.
I got some stuff from the local surplus store. You can use through hole resistors easily on the pads. Everything bog standard really.
You need the adjustable version of the mic https://nl.mouser.com/ProductDetail/998-MIC5156YN
If you are using the "through" hole version get this pot: https://secure.reichelt.nl/nl/nl/pr...den-staand-10-k-ohm-64y-10k-p2716.html?&nbc=1. The smd board cleverly allows "all types"
Heatsink: https://secure.reichelt.nl/nl/nl/ko...-sk-129-38-1-p228064.html?&trstct=pos_1&nbc=1
So sorry no bom.
Polarised work fine if connected the right way. Removed these. Shows that polarity is reversed.
