Babelfish XA252 / Babelfish XA252 SIT / Babelfish XA252 SET
No fuse didn't pop, held all the way up to 120V A/C, and that is where meter pics are at. Measuring bias across one of the big resistors,
Offset is with meter on speaker outputs.
no need for further check of components if you actually got that, it actually seems nothing is wrong
now, leave DC Offset trimpot untouched, just increase Iq with Iq trimpot
goal is to have 180mV measured across big resistors
180mV=0.18V
  • Thank You
Reactions: Russellc
Other channel, now at 100 mV, 150 and let sit a few seconds...variac at 120 V, well 176 mV is as high as pot will go...
This channel not so good, bias stops at 176, offset at 15 mV. Adding jumper raises it to 127 mV, pot having no effect.
What did I kill now?
Russellc
and once when you hear it, you can contemplate here aloud, how those fuse popups happened?
I know. Do you really want to hear this? More silliness caused by crimp connectors on A/C input/fuse dohicky. Bad fit, so intermittent on/off. Solder to the rescue.
Several cycles on off, all good except could use more range on one bias pot. Someone else wrote here with same problem, think a resistor change cured that? Will have to go back and reread. Once warm it was 180 mV.
Dr appointment, then re heat and sit a while followed by test speaker hookup.
russellc
