Are you using the OM5284 now?yes, my servo board works. In practice it fits very well as HECD-019a.
I wanted to ask you a question, do you know if the service manual for the servo board for CDM PRO Vau1252 is available? I have a problem with a Mark Levinson n37, the drawer does not open and close and the problem is on the servo board, there is some component short circuit.
I think the drawer is nothing to do with the CD-PRO, the DSA of CD-pro, even don't have the open close command!
CD6000 no need any DSA, the DSA controller also control the SAA ic by I2C, and convert the command to DSA for MCU.Dear Sergio, I am working on an Audionet ART G2, based on Marantz CD63 or CD6000. As far as I can see the communication pins which are labeled AuxBack, AUX1 Data and AUX3STB on HECD-019A are labeled DSA ACK, DSA DATA and DSA STRB on the Audionet connector. Would your board support this kind of communication?
Best regards from Germany
Benedikt
Yes, exactly, the drawer opening and closing controls are external to the servo board.I think the drawer is nothing to do with the CD-PRO, the DSA of CD-pro, even don't have the open close command!
However there is some "interference" between the servo and the player controller.
But according to the tests done by another forum user there is an anomaly in the board, there are 390 ohms at a specific pin that shouldn't be there, there is certainly a short circuit somewhere that creates problems with the drawer controls.
For whom could be interested Aliexpress sells this kit:
https://it.aliexpress.com/item/1005...t_main.10.5ccc3696qinrmQ&gatewayAdapt=glo2ita
It's a beautiful servo board, DSA compatible for CDM12 OPU, could be purchased with or without controller and brushless motor and it's full functional!
can you share the this gerber?
really interesting, it is possible to find these CDT612 PHILIPS MICROCONTROLLER FOR CD SYSTEMS, QFP44 RETRO SOUND SYSTEM UKSTK: https://www.ebay.it/itm/225889157696 but is there a diagram of a player that uses it? and is it possible to use your printed circuit instead?
- Digital Source
- Clone SERVO CD HECD-019A for PHILIPS CDM12.1
