FYI, https://www.speakerdesign.net/WinPCD/ Windows software based on Jeffs Excel spreadsheets - gets around the Excel compatibility issues and macros.I have Excel but as mentioned win11 doesn't like macros. I may hav eto manually enable them one by one. A bit of a Xmas quiz !
Also reading the linked post Vituixcad is listed as doing series Xovers which matches my experience with it.
No measurements for a a while as its time for Christmas.
A Merry and Peaceful Christmas to all.
Thank you stretchneck for the link to speaker design.
I will have a look in next few days. I will let you know how it goes.
When trying to follow the trace and component placement on the back of the x-over. Not sure I got it right.
Interesting find, resistor's in parallel. I am sure someone will verify your decode.
The Tweeter may or not swapping polarity?
In the original post and picture of the topside the connectors are indexed as +/- which is copied for each of the other connector pads? A minor point as a quick measurement would show correct phasing.
That doesn't seem right. 0.9 ohm across L2 makes L2 effectively do nothing in my quick modeling of it. I was using other driver data (Beta 10 and JBL compression driver), but the basic crossover function should still work, unless I screwed something up in my model.
Same pcb board. Any idea$s.
from post #1 White Mundorf Cap EVO aluminium Oil 450VDC Caps , the coils fill the board
$30 usd Mundorf Cap 10ufd
https://partsconnexion.com/collections/mundorf-evo-aluminum-oil-film-capacitors/products/mundorf-capacitor-10uf-450vdc-mcap®-evo-oil
from post #11 Solen PB-MKP-FC 400 VDC Caps, the coils don't fill the board.
$6.55 usd Solen Cap 10 ufd
https://partsconnexion.com/products...-400vdc-pb-series?_pos=8&_sid=6d8df40b7&_ss=r
Ok, I will open up my AD612 once more and do a better job. This sketch was just a hasty job to try to help out.
from post #1, note the resistors placement.
A two way 2nd order series crossover design
https://www.diyaudio.com/community/threads/a-two-way-2nd-order-series-crossover-design.291610/
One of those Rs, the one on the woofer is unnecessary.
2nd order, drawn a bit weird.
dave
Really helpful, thanks. Congrats on owning such a great set of speakers. I would love to have a big enough listening room to own a set myself.
L-Pad on Series Crossover?
https://www.diyaudio.com/community/threads/l-pad-on-series-crossover.397411/
post# 5 AllenB
post #7 Wolf
Tony Gee
https://www.humblehomemadehifi.com/download/Humble Homemade Hifi_HATT Mk-I + Mk-II.pdf
post# 5 AllenB
post #7 Wolf
Tony Gee
- Heretic Loudspeaker A612 Clone
