High quality class AB 100 watt amp
one hope is for the depth of negative feedback - at least 90 dB deep at a frequency of 20 kHz - I think this is a separate class of amplifiers as “ultra deep NFB”
Seen that. Wolverine @ 20K has 70db total , about 38 "extra" for correction. This is with TMC. Some 3 stage hitachi IPS's can muster (90 gain)
extra at 20Khz. IPS's such as these , you need "fancy" (lead /lag) compensation to keep phase margin.
TMC also trades margin for extra 20K gain.
Some designs (symmetrical - leach) are just more linear natively (below 2) , can still get <20PPM 20Khz with simple miller and only 30'ish NFB. Margin (90 deg.) stays
large out to many Mhz. I've omitted any comp. on these types and they still won't oscillate (or they just "rang" on a square wave). Still , a small miller
to define the unity point is good practice. The miller does not slow down even a CFA (much).
This is the quality level of Hi-Fi from the 70s of the last century)))
just not as “fancy” as Leach, just a progressive correction.
The input stage of a symmetrical Leach has a gain at a frequency of 1 kHz as much as -4 dB (nonsense), and the nonlinearity of this open loop stage is +/- 10 dB. the depth of the NFB at a frequency of 20 kHz is only 16 dB. and there is completely no neutralization of the internal resistance of the VAS multiplier.
What is there to comment on?
You are in English audio forum and progresive correction means nothig here.
Better read Cordell and Self audio books to learn about audio and the types of compensation (not correction).
There are different compesation types as TPC (Two Pole Compesation) TMC (Transitional Miller Compensation) and off course ordinary Miller compensation.
Cherry suggested that compensation capacitor could be connected to the amp output.
Here you can see samething new here, OITPC: https://www.diyaudio.com/community/threads/oitpc-output-inclusive-tpc-not-tmc.317335/
Damir
Don’t mislead the forum, you seem to be doing this on purpose because you don’t understand the essence of progressive correction (compensation for you).
ok, these are good books, but they didn't write about dynamic frequency filtering using the state variable method, which can be used to correct amplifiers.
for your version, ok, but not for progression, because Cherry an increase in the filtering order in the feedback circuit is used, so you either do not see or do not understand the essence of progressive correction. (or compensation if that's how you like it).
Could you explain that progressive compensation (or correction if you like more), as in those books I mentioned before there is nothing with this name?
You already call it “progressive compensation” - that means you are making progress.
Much of the methodology has already been indirectly described above. It may not seem obvious to you for application, but high-order compensation in the general negative feedback circuit does not seem obvious to me, especially for an amplifier in class AB.
And your next question is where amplifiers with such a technique are - these are not my developments and it’s not for me to share them on the forum, but ready-made simple amplifier blocks are quite suitable as an option for finalizing the finished product. Not every amplifier topology is suitable for progressive compensation; here on the forum I saw only one such option for radio amateurs, interesting, because he works for a company that produces amplifiers for concerts.
the Author of this thread wants scheme+pcb+guide of 100W amplifier or he wants to create his own design or amp based on some design...
here on the forum there are ready-made solutions for repetition; many have been setting up modes for years to get a high-quality amplifier.
Judging by the author’s posts, it will take him at least 5 years to create something of his own.
It is best to use a ready-made solution, and even better when the author of the finished amplifier is here on the forum and can suggest the nuances.
Why you talk about “progressive compensation” if you can't explain it here, this is DIY forum and poeple like to built.
Reactions: Zohaib Ahmad
