Power Amplifier LJM L20SE
This is my MOD of the original L20SE (with the real Toshibas TTC5200 and TTA1943). The multisim file is attached to this post.
you have positioned the R1C1 input filter incorrectly
the L20SE kits had been delivered from china. I measured the output transistor holes and the mechanical holes to get them similar to the original pcb. Well done, i think.
I made little changes on my pcb to get some copper lines shorter, moved a transistor and capactitor and other little things.....finished and uploaded now. jlcpcb...
Exciting to me 🙂
I made two 4µH coils on a 26 mm kukident roll. 🙂
I have got all teeth...kukident is needful for the toilet...and for copper coils 😎
Greetings
Peter
Reactions: Hennady Kovalsky
The input and output filters operate outside the 20-20 kHz frequency range of your best DAC.
1. Regarding the input filters (also called High Pass filters, or just HP filters):
  • In order to to push the input cutoff frequency below 2 Hz the HP filter must consist of a 5-µF coupling capacitor. These are either electrolytics (with all their problems), or bulky and expensive film capacitors like, for instance, Wima MKP 10.
But, there are well known reasons not to use them:
  • "First, because all practical HP filters progressively delay low frequencies relative to the rest of the music. Every added HP filter pole only adds to this ‘signal smearing’ [10]. Simulation in time and frequency domains shows this [11]."
  • "Second, because HP filters require the use of capacitors. Capacitors that are almostideal for audio and not outrageously expensive and bulky, are limited in type and
    values. Capacitors which are Faradically large enough not to cause substantial ‘signal smearing’ are in practice medium type electrolytics, and not in practice nor in theory anywhere near so optimal for audio as other dielectric types.
  • "For these reasons, even routine HP filtering (alias DC blocking or AC coupling) may be absent altogether."
source: pg. 65, High Performance Audio Power Amplifiers, Ben Duncan, 1997, ISBN 0 7506 2629 1
Electrolytics are simply not that bad, -110dB or below isn't that hard to achieve as DC-blockers, especially with bipolar electrolytics. And given their very wide tolerance bands you can't really use them for anything but decoupling and DC-blocking where they can perform fine.
And for an audio HP active filter all you need is somewhere around 220nF to 470nF film caps, no need for larger values that might necessitate electrolytics or even bulky film caps. Cut-off frequency around 15 to 20Hz is usually involved, not 2Hz. That's DC-blocking territory where precision in capacitor values isn't needed and you just use a large electrolytic.
The ones you really have to avoid are high-K ceramic - I've seen fake film caps that have a X7R ceramic hidden inside for instance - get caught out by those and your 0.0001% distortion filter suddenly becomes more like 0.1% or worse...
Hum... let's see:
"With a 20 kR input return resistor, a 5 µF coupling capacitor is required to push the input cutoff frequency below 2 Hz. This capacitor should be of very high quality."
source: pg. 155, Designing Audio Power Amplifiers, Bob Cordell, 2011, ISBN: 978-0-07-164025-1
The formula for frequency cut-off is fc = 1/(2*Pi*R*C) Hz.
In the L20SE, the return resistor is the 10K R2.
So, to achieve the desired cut-off frequency below 2 Hz, the coupling capacitor should be 8 uF (cut-off: 1,98943678864869 Hz).
To avoid electrolytics you would have to either use multiple expensive/bulky PP/Polypropylene, or look at the less than optimal PET/metallised polyester (not exactly the realm of "this capacitor should be of very high quality").
To be more precise 6.8uF
That's right, that's exactly what I use
not true, because The cutoff frequency should be lower by at least an octave, or even better by 10 times i.e. at a frequency of 2Hz. This is due to a change in phase.
It's good that you're reading Ben Duncan, read it again.
unfortunately it only seems to you (...) This is a forum, not science, I’m not going to teach you anything, you either agree or move on...
I apologise for the distress, offence and disturbance my questions and comments have obviously caused you.
I'm sorry to have troubled you.
P.S. "abracadabra" on your avatar - is that your name? ))))
Yes, it is my real name, rolled by a simple cipher. And regarding the picture in the avatar, yes, I am a real doctor (MD) and HIFI and audio DIY has been my hobby for the past 45 years (I am old, but still have very good hearing).
Therefore, treat my comments on the diagrams as text encrypted by specialized education...
very good, therefore, over 45 years of audio hobby, one could hear by ear all the nuances of amateur radio design and the use of reactive element ratings, especially in simple amateur radio circuits...
Reactions: XPZMIePKdFlkA
More often than not the source already has a decoupling cap so if you are doing the amp for yourself you may not need additional coupling caps.
My amp don't have a coupling cap and my source is dc coupled (5532 direct via 100 ohm resistor) and there are no issues. The feedback filter in this amp lowers the gain at DC so a small amount of DC on the input stays small.
If you insist on a coupling cap I suggest you test them is your system. You may find that you prefer a 47-100uF BP elyt over a 5-8uF PP cap.
PS, that table is too general because you cannot possibly claim for example, that every Tantalum between 0.1 and 470uf have identical characteristics. Same for all the others.
Your statement contains a syllogistic fallacy. You cannot possibly claim, for example, that the author states or the table implies that capacitors within each class of dielectric capacitor types must have identical characteristics. They only need to be typical enough to be grouped into each class of capacitor types.
