Iron Pre Essentials Kits For The DIYA Store - Register Your Interest
I also enjoy seeing different ideas about building here. Using a different enclosure for a project is, well, educational sometimes. Especially when you have realized that the enclosure that you are using is too small. Sometimes, that is the reason I end up using a separate power supply. Indeed, one wire at a time.
Guys, I can tell you that the RCA jacks that I am using are temporary! I do not like them at all. Neutrik costs more for a reason apparently. These are cheap Chinese copies. How many times must I learn this lesson!?
It's ok, but that is a lot of wires to be disgusted at one at a time.
I will finish up and listen for an initial audition. Having said that, one of the most important aspects of a build to me are connections. So then, if started out with questionable connections, the audition is already colored in my mind. We'll see.
Yes, I've long ago given up on cheap RCA jacks. I find that REAN is also a good-quality product and I've used probably a hundred of each color now.
My chassis is so tight front-to-back that the boards only fit because they are on spacers, and so just barely clear the front and rear panel flanges.
I agree about connections, particularly with small signals. They require the most direct connections that won't degrade over time - same reasoning with using high-quality relays with contacts that have very low resistance.
Reactions: Ixnay
I basically agree to this. However, knowing myself, I prefer to keep the capability of removing the main PCB until I'm sure everything is fine. I can always replace the (gold-plated) contacts of the small signal lines with soldered connections.
In this case, it showed not to be necessary, as the only mistake I did was to use the switcher PCB the wrong way around (that was before the guidelines were available).
Reactions: Ixnay
Man can I relate. There is nothing more invasive than resoldering your soldering. I am about to find that out, since I hate the RCA jacks that used for this unit. Fortunately, there is slack enough in the wiring to do this. And for what it's worth, I already had to resolder the incoming AC on the board. Yup, I soldered underneath the board to look neater. WTH?
Yah, just had a breakthrough! Slightly drilled out the RCA mount and fitted Manley RCA jacks perfectly. Time to go to work.
Because the actual barrel size of RCA jacks is all over the place, I had to increase the size of the hole in order for the Manley step washers to fit (that may not be needed with other jacks). Manleys are larger than others out there and so you end up with a 1/2".
So to answer your question, no these were not blanks (though I wish they were). These came with installed jacks that are junk. Yup, the ones that will take solder very poorly before melting the inside insulation of the jack. So they all ended up in the trash, and that is where the drilling began. Pretty soft metal. With a drill press and vise, it is child's play, but watch for wandering of the step bit anyway.
When it is all said and done, each Manley/Chinese drilled blank jack will run $8-10 each. >>If instead, you order Neutrik jacks in the first place, they run between $6-8 each, depending on color. For a guy like me, only black oxide bolts will be used (they do not come with either brand of jacks), and adding to that the cost of hex nuts and internal star washers, the total cost is more but i haven't calculated it in.
Reactions: birdbox
Perfect, thank you.
Speakers in the house now are 90 and 93db. All future will be above 90, only question is how far. Spousal permission for one more set has been attained....and this has led to much trepidation. To horn or not to horn? So many choices in the DIY domain, hard to decide. I almost sprang for a Troels Gravesen 3WC-10 but have been having second thoughts.
Also, seems the amps I love most tend to be a little squishy in the low end.
I need a t-shirt that says Ohm is everywhere!
Check out X's XSD speaker build. Hugh soundstage, (open baffle) reasonable efficiency, I believe 92 dB. Most revealing speaker I have heard in a while.
You will love your Iron pre, seriously.
Russellc
It's tough when you get this close, right? I got mine up and running, yet the LED's need to be connected. Then there are the little things that you forgot about.
I am already getting parts for the next one to build. It becomes quite a list.
I even organized all the other projects ( new ones and spares for old ones ) into plastic baggies so I could order across projects to minimize shipping....and still missed a few. 🤦‍♂️
On the bright side, Mouser has a warehouse in central TX and organizing gave a good inventory of truly spare parts so I now know I can build a couple more simple regulated bipolar power supplies for other pre's that are already built, but homeless, ( DIY FE 2022, B1K, BA3-FE, etc. ) with very few additional purchases.
On and on it goes!
