Pearl 3 Burning Amp 2023
Now getting some significant hum from the Pearl 3. It's definitely from the Pearl 3, if I disconnect the tonearm cable (VPI lemo connector), hum gets worse. Additionally, if I touch the Pearl 3 RIAA box hum goes down. I will check everything tomorrow and ensure I have good bare metal contacts on each part of the chassis. I wired the unit like the build guide, so I'm not sure what else to check. I'll keep investigating but if someone else found a good way to isolate hum please let me know! Thanks!
As requested:
Maybe also check the eight PCB mountings that they don't "short" PCB ground plane to chassis?
It was a topic some posts ago that it might be a good idea to use nylon shims to isolate the PCB ground plane.
As far as I can see the ground plane edge at each PCB mounting hole is gold plated so a metal shim should not touch that gold placed edge.
Also if you use metal standoffs then these standoffs should not touch the ground plane (I use plastic spacers).
Will check. I thought I checked all those but I'll check again.
You might consider connecting the inside of the turntable ground post to the DC-in ground, in addition to the audio grounds of the Pearl 3 as you have done. That's what I did. You could try it live with alligator clips & see if you hear the hum drop.
The recessed ceiling lights in my listening room radiate a lot of hum. Originally I thought it was coming from my turntable.
Reactions: Auricle
@msikk
Hmmm… this is perplexing. Everything look right, as far as I can tell in the photos, there are some details obscured by lack of resolution, but that’s easy to fix moving forward as needed.
So let’s begin by simplifying things a little, please disconnect the balanced outputs at the PCB and see if that makes any difference.
Also the umbilical at the RIAA chassis should have shield on pin 1, and pin 1 at the XLR Jack would be connected to the tab on the connector itself as shown. You may have it wired as shown, but can’t tell in your photos.
