Pearl 3 Burning Amp 2023
Hello Meper,
Ortofon recommends a load capacitance of 150 - 300 pF for your 2M BLACK LVB 250.
If you say, that your phonocable + tonearmcable has together around 40 pF, then subtract that from
the value ORTOFON recommends: 150 pF - 40 pf = 110 pF (min.) and 300 pF - 40 pF = 260 pF.
Try it and believe your ears! There is no 'golden rule' for that value. It will influence the highs a lot.
I also agree with freebee...
With vinylplayers you can try a lot.
Cheers
Dirk 😉
I adjusted the VTA after I took the NAD out and inserted P3.
The arm was lowered a bit so VTA was reduced (VTF the same about 1.65g. I just finetuned it after VTA adjustment).
Using google it seems that less VTA should not enhance "brightness".
I used google again to find specs on NAD riaa:
"Indgangsimpedans: 100 ohm/180pF (MC), 47kOhm/200pF (MM)".
It seems to be born with 200pF at MM settings. Then maybe I could try with 220pF to start with and check if I notice a difference.
I will later pickup new cut RCA cables (0.4m, 0.5m) + power cables (0.5m). Then TT will go from 1m to 0.5m RCA (so even less pF). The much shorter power cables will make less mess behind the rack system and I can better isolate signal cables from power cables.
The P3 has a Zobel filter to dial-in. But I don't experience oscillations or other kind of instability.
What is your experience with how load capacitance changes the sound of the "high end" (it is a MM cartridge)?
I tried switching in 100pF to my Ortofon 2M Bronze MM loaded at 47k. I didn't hear much difference but also didn't listen long.
With an Ortofon MC in a different system, loaded at 50R, we noticed some high end roll-off with 100pF added. People with younger ears than mine preferred the sound without the shunt cap.
I have prepared P3 with 220pF dialed in. I need some food (dinner) first. After that I will listen to the setup with a good glass of red wine.
Also with trimmed IC's (picture). The ground wire not yet trimmed. On P3 I use a speaker post and I use banana plug in that end. It would be much easier if that was the standard for these connections instead of "fiddling" with those tiny ground screws.
Reactions: 6L6 and DualTriode
+1
I use banana plugs often for bonding/grounding things together. They are quick and easy.
I use different color banana plugs and conductors for connections to bench power supplies.
Just for grins I use barrel connectors for the other end of the power supply conductors to the DUT.
https://www.amazon.com/dp/B072BXB2Y8?psc=1&ref=ppx_yo2ov_dt_b_product_details
Reactions: MEPER
The 220pF made quite a difference. It took away the pronounced S-sounds.
Now I can enjoy the music. Interesting the difference between various records in relation to groove noise.
it seems the record company Epic use really silent Vinyl. I opened up a brand new SRV record and was surprised how "silent" it was.
I like when there is no groove noise "also" between the tracks. I wonder if it is the master or the vinyl that is responsible for this. Probably both.
No doubt the P3 is a very nice riaa.
Reactions: ranshdow
