DIY Class A/B Amp The "Wolverine" build thread
I'm afraid it's a device you connect to an oscilloscope or computer having compatible oscilloscope application installed. I bought a tracer device long time ago to match mosfets. I should still have it somewhere but have only a vague memory how to use it.
Of course one can build such a device having it's circuit diagram.
What do you think of PyPsuCurvetrace, the Python script developed by @mbrennwa for transistor curve tracing using two programmable PSU?
I am of course biased, but I can say that it works very well. It's in the public domain, so anyone can use it. More here:
https://pypsucurvetrace.readthedocs.io/en/latest
Accuracy is determined by the accuracy of the meters in the PSUs. If that's not enough, you can specify your own calibration to pypsucurvetrace.
One cool aspect is that pypsucurvetrace allows controlling the temperature of the DUT, which is crucial for testing of power transistors.
Reactions: sp33ls
What are the operating points of the following devices?
1) Q1 and Q2
2) Q3 and Q4
3) Q5 and Q6
4) Q105 and Q106
5) Q107 and Q108
My idea for matching the transistors is to use two power supplies, a couple of resistors and a meter to measure Vbe and beta at the operating point.
before I start buying parts in earnest I thought id see if anyone has any spare matched resistors they would like to part with? I'm looking for CMF55 matched resistors for R3/4 100r will need 2 pairs for these and R7/8 220r again would need 2 pairs. Does anyone have them?
Voltage rails 57V.
My output transistor are Toshiba 2sc5359 2sa1987.
and in accordance with the instructions SOA the volts for these transistors according to instructions from member Harry3 (Γεια σου φιλε μου ) must be about 40-42VAC.
I have two toroidal 2X42V /230Vac 400VA and with the sag gives me about 57Vdc.
I hope to hear something better than the best.
Reactions: smangus
Hi guys, I need some help with the psu design for a two channels wolverine. Is it correct to say that I have the following options?
1) Single transformer with dual secondaries PSU, with one DC+ and one DC- outputs: in this case I connect the two V+ rails of the two channels to the DC+ output of the psu, and the two V- rails of the two channels to the DC- output of the psu.
2) Two transformers with dual secondaries PSU: in this case each transformer has a DC+ and a DC- output. So, the rails V+, V- of each channel are connected to the DC+,DC- outputs of each transformer, respectively. Basically, each transformer separately serves each channel.
Then I have the following further distinction: in both case 1) and case 2) if the two secondaries are center tapped I use a single bridge rectifier, whereas if I have two "separate" secondaries I need a bridge rectifier for each secondary. It follows that I have the following choices:
single transformer + center tapped dual secondaries -> single bridge rectifier;
single transformer + separate dual secondaries -> two bridge rectifiers;
two transformers + center tapped dual secondaries -> one bridge rectifier for each transformer (total of two bridge rectifiers);
two transformers + separate dual secondaries -> two bridge rectifiers for each transformer (total of four bridge rectifiers);
Is it correct? Which of these solution is preferred?
Ok so single transformer is nice in that it is a simple clean layout and you could maybe have one much larger transformer for similar cost...
Dual transformer allows "dual mono" layout but it does require 2 sets of 2 bridge rectifiers, capacitors banks and some more mounting hardware etc. etc.
I have had good results with either layout.
But I chose dual mono for my Wolverine build.
Something to consider is a switchedmode power supply also.
- Dan
Reactions: ghitus
