Simple OTL for beginners?
Wind your own OT. 800 turns on the core already. $45 Like 40 turns for the secondary. Circlotron 3200 Ohm primary.
Well, an output impedance of 3200 Ω in a Circlotron transforms into 3200 * 4 = 12800 Ω in a conventional PP amplifier with the same tubes operating at the same conditions. No that useful, is it 😉 ? Hence, decreasing the secondary turns number to 20 would give a more useful primary impedance of 800 Ω.
But what about that 50-400 Hz frequency range written on that toroid?
Best regards!
OTL amplifiers are not necessarily big, heavy and complicated - see mine some posts above !
A good inspiration for a simple, stable, reliable and efficient circuit is to consider Mr Julius Futterman's orginal patent and circuit filed in 1953 :
https://patents.google.com/patent/US2773136A/en
That's exactly from where I started for designing and building my U-OTL6080 :
T
Reactions: ElArte
This is not pure OTL amp since use simple autotrafo on output , it is vintage schematic and is from famous Russian designer Krylov ,
Warning !!! , main isolation transformer 220V~/220V~ is not shown in the schematic and is apsolute Mandatory !!!
Reactions: deanznz
Ah, I would have expected that you'd converted that well known OTL design by P. Dickie and J Makovsky with three 6082's from series heater to parallel supply:
http://www.audiodesignguide.com/otl/6082.gif
Best regards!
Reactions: tubelectron
Yes, and with an isolation transformer you can replace that lonely 1N5408 diode by a bridge rectifier.
Best regards!
Agreed , think that the simplest way is to start with some standard main isolation toroid transformer 235V~/220V/220V~ , where mising 6,3V~/3A winding can be added manually , also output autotrafo can be some very small toroid type since it is not loaded with any DC component .
Best Regards !
re: Kay Pirinha
Yes, I forgot the 4X in Circlotron mode. But the secondary needs -twice- as many turns, ie. 80 turns, to bring the primary down to 800 Ohm (for the 3200 Ohm P-ct-P equiv.).
These current transformers are rated for some accuracy in measuring main line current. So a limited freq. range will be specified. Having the extension to 400 Hz probably means the core has a thin lamination, just like an audio one. Capacitance in the core winding has to be minimized for accuracy versus freq, so the winding is likely a long progressive wound one around the core. Just like a Plitron! And your primary is rated for 5 Amps! You probably do want the high turns current transformers for tube use.
With one of these fixup OTs on the OTL (think of "postprocessing") you'll only need a couple of 6L6s for output tubes. Big power and heat savings.
I ordered a couple of the cores to try out, I will test the freq. response.
I know some will not stomach a post processing xfmr for their OTL, so then you'll just have to brute force it:
Reactions: banat
Best regards!
Hi @Kay Pirinha !
Yes indeed, the Dickie and Makovsky OTL circuit is well known - I have the complete article somewhere on my PC, but never experimented it, because with more NFB loops, more stages, it is more complex than the Futterman 1953-1956 original patent circuit, which I took as the basis of my design...
My U-OTL has one power transformer which provide the requested high and low voltages from 230 or 240VAC 50Hz that we have here :
Of course, I would not have used the mains directly ! Not because it doesn't works (and it works well, I tested it), but for basic insulation safety reasons, in order to avoid any possible electric shock with the mains network.
T
And Russian original counterpart to US-7242 ; 12C42C , triple low Rp triode , formed from 3 triode , 120 degr. distributed in one glass bulb , ideal for OTL amps ,🙂
and also simmilar tube 654 from development process .
Yes, twice the secondary turns number, of course, to get the primary impedance down to a quarter. Must have been still sleeping this morning 😵 ...
Btw, where fron do you know the primary turns number? And which maximum output power would you guess with this kind of transformer?
Best regards!
re: Kay Pirinha
The Ratio 4000:5 Amp rating on the tag gives away the 800 to 1 turns. (4000/5 = 800:1 ) 5 Amps rating for the winding, 4000 Amps for the mains.
I'm guessing that the 600V tag rating is saturation V for the winding, not sure. (@ 50 Hz?) Typically want to run below 0.7 saturation for linearity.
The 10 KV should be the isolation V to the mains bus-bar. Educated guessing. Could check the Cat No. at the manufacturer or the class rating standard.
From searching the internet: 8RL-4002 seems to be a GE equivalence #, Transformer ID dimension is 3.25 inch, class 0.3 is 0.3% accuracy for utility billing, Rating Factor of 0.8 (20% derated from max??? no explanation yet), current ratio 4000:5 4000 Amps on mains will give 5 Amps to the metering, these things get installed with a shorting strap across the winding initially to prevent electrocution - haven't seen a max V listed yet, but could be that 600V #. From picture scaling: 3.25 inch ID gives 5.75 inch OD
The GE datasheet for the 8RL-402 current xfmr says 80 VA. Winding resistance of 0.973 Ohm. The 0.8 # is a continuous thermal rating factor, whatever that is. Hard to believe 800 turns would be 0.973 Ohm, but probably needed for 5 Amps. Taking 75 VA and dividing by 5 Amp would give 15V. (@ 50 or 60 Hz ) The graphs on page 2 do show it flat lining around 25 V. UH-OH, this may NOT work for a tube OT!! Two toroids would handle 50V. Would also work for higher frequencies. At 400 Hz, should work for approx. 8 x 25V or 200V.
What about a stock 2 * 115/24 Vac toroid wired as an autoformer according to the sketch in #44? When loaded with 8 Ω, it would give a primary impedance of about 800 Ω, ideal for a Philips design with a pair of EL86/PL84/UL84's. I don't know that much about stray inductances in mains toroids, but would give it a try anyway.
Best regards!
