diyAB Amp The "Honey Badger" build thread
Right channel amp board photos
I'm checking my right channel resistors, but I've noticed I neglected to install the 1/2w - 1w 12-15V zener diode for my cascode option [#1].
I will put it in now. Could this have been causing my issue?
Does it matter if its 1/2 w vs. 1W?
Can you say more about "creepage problems"?
You need a certain amount of gap between the solder pads depending on the difference in voltage otherwise the voltaged can jump the gap. There are creepage tables on online. For example if the difference in voltage between two pads is grater than 64v but less that 81v the gap between the two should be 1.3mm so if you have a massive blob of solder on those pads you will reduce the gap with could allow the voltage to jump the gap, just like a short.
