Speaker Turn On Delay and DC Protector Board Set (V3)
I see the speaker protection circuits, disconnecting speakers as soon as d.c is present in the output and connecting speakers again when d.c stops.
How we can latch the last(fault )condition,no speaker reconnection up to power reset.
here is the datasheet from upc1237... it does have latching.
pin 3 does the job of latching.
Prasi:
A follow-up question: what part did you specify for B2?
Regards.
Any of the following will work fine. 5.08mm x 7.62mm pitch.
https://www.mouser.in/c/semiconductors/discrete-semiconductors/diodes-rectifiers/bridge-rectifiers/?if - forward current=1 A&mounting style=Through Hole&package / case=DFM~~DIP-4&instock=y&sort=pricing&rp=semiconductors/discrete-semiconductors/diodes-rectifiers/bridge-rectifiers|~Package / Case
Also attaching slightly modified files, where in I have removed the solder mask for speaker traces and also added a pinheader for ground reference.
Any changes to this design? Has it been proven to work?
thanks very much
Whats the time on the turn on delay and how would I increase to say 15 secs?
