Thanks. 🙂
However, the current developments in the Ath thread show that the effort to integrate a midrange driver is basically no longer necessary. Either I or my printer are too slow to keep up. 😉
Hi all,
Amazing to see all the great projects people are sharing. Besides just getting inspiration from all people contributing to this forum, here's our two cents from Addit Audio.
This is our take on a high output monitor speaker. We call her “The Monihorn”. The speaker features a 440mm ATH horn as basis with midrange ports for 3 4" mids. A 12" driver with a passive radiator takes care of the lowend. It's a 3 way design with DSP and amplification onboard.
The cabinet itself has been 3D printed in one piece with a large scale industrial printer. Print time around 10 hours. Material used was PETG (post industrial recycled PET with 30% glassfiber) . The woofer and amp holes were cnc milled after the printing. Horn and woofer mounts are all 3D printed with a MJF printer. Foam was used to fill the hollow print for added stiffness and dampening. Essentially creating a composite sandwich.
Here are some measurements and photos from the process!
Afbeelding van WhatsApp op 2023-11-25 om 20.41.24_db844148.jpg220.4 KB · Views: 537
Afbeelding van WhatsApp op 2023-11-25 om 20.41.23_f5b68de0.jpg215.4 KB · Views: 529
Afbeelding van WhatsApp op 2023-11-25 om 20.41.22_bfee0215.jpg180.6 KB · Views: 610
Afbeelding van WhatsApp op 2023-11-25 om 20.34.37_1ed05c4a.jpg107.4 KB · Views: 584
Afbeelding van WhatsApp op 2023-11-25 om 20.34.44_dbd3a1a7.jpg99 KB · Views: 589
Afbeelding van WhatsApp op 2023-11-24 om 21.13.10_3dc643aa.jpg69.5 KB · Views: 549
The speaker's a creative design, and the measurements look great.
But never mind the speaker. That is one hell of a CNC!
Aha! Now as you share the design in the "Make" thread, would you care to present also the other driver make and type? 🙂
Drivers:
CD - B&C DE250
Mid - B&C 4NDF34
Low active - B&C 12BG100
Low passive - Dayton Audio RSS315
MEH simulation and ATH params I need to dig up somewhere
CD - B&C DE250
Mid - B&C 4NDF34
The design goals were (pretty standard):and tell us about the Horn MEH simulation/ ATH script?
- consistent DI (throat adapter to prevent beaming)
- wide coverage
- directivity control at least down to ~1000hz
Here's the ATH script for this version:
Code:
; ATH 4.9 20230530
; MoniHorn v2
; CircSym mode
; Throat adapter
Throat.Ext.Angle = 5
Throat.Ext.Length = 22.5
R-OSSE = {
R = 197.15
a = 39
r0 = 9.5
a0 = 23
m = 0.76
r = 0.30
q = 3.65
k = 18.6
b = 0.0
arcterm = 160
Rot = 0
Mesh.AngularSegments = 64
Mesh.LengthSegments = 40
Mesh.SubdomainSlices=
Mesh.RearShape = 1
Mesh.WallThickness = 5.0; [mm]
ABEC.SimProfile = 0
ABEC.SimType = 2
ABEC.f1 = 250 ; [Hz]
ABEC.f2 = 20000 ; [Hz]
ABEC.NumFrequencies = 100
ABEC.MeshFrequency = 40000 ; [Hz]
ABEC.Polars:SPL = {
MapAngleRange = 0,180,37
NormAngle = 20 ; [deg]
Distance = 3 ; [m]
Output.SubDir = "monihorn"
Output.STL = 0
Output.ABECProject = 1
Report = {
Title = "MoniHorn throatring v2"
NormAngle = 15 ;
Width = 1400
Height = 900
SPL_Range = 50
MaxRadius = 90
PolarData = "SPL"
OffsetFR = 0 ; [dB]
GnuplotCode = 2x2n+w.gpl
- Acoustic Horn Design - The Practical Way
