I am worried about the metal standoffs digging in the thin cap sleeve, the Cap Body is Positive The standoff where the nut is located is only separated by Varnish from the - ground of the UCPure.
With a bit of time or bad luck you could have a huge short. I suggest using Plastic Standoffs and strapping the caps independently from the UcPure or different design. Other the that that is a great way to do 15.5V I learned the hard way years ago with a regular cap. Hope I did not hurt any feelings I thought I say something.
Yes, thank you for your concern and advice. Actually, this is Crom's photo not mine:
https://www.diyaudio.com/community/...epo4-battery-power-supply.327105/post-6886105
Yes, I only exclusively use Plastic Standoffs and Plastic Nuts for all my Ian gear since the beginning. I also only exclusively use trusted Brand Name Balancing Boards like Eaton or UcBalancer. That's why I waited years to implement the UcPure since I had the Eaton Balancing Boards on backorder.
I even double washer just to make sure nothing touches the Cap Body:
It's just my memory is bad so I forget how many Balancing Boards are needed for 12-15.5V. I believe it's three. That's why I posted Crom's photo because that is the closest we have on documentation on how to implement a 15.5V UcPure solution.
I was hoping there would be an updated UcPure/UcBalancer 15.5V photo / documentation by the time I implement.
So since the Group Buy will end soon, does a quantity of three UcBalancers sound about right for a 15.5V solution? With Ian mentioning the awesome measurements of the DRIXO (I love my DRIXO) with the UcPure 15.5V, I think this will be my next Summer Project.
Nice, the Tecates. I remember them.Here is my setup…..
Thanks for the alternative configuration. I did not consider a lying flat stack.
So I see 3 Balancing Boards, but not UcBalancers.
Do you think all I need is a quantity of three UcBalancers? I don't want to be in a bind when I start implementing for my next Summer Project and find out I'm a UcBalancer short of implementing properly.
Sorry for the simple question, my memory is bad so I forget the proper configuration for a 15.5V UcPure solution but I want to make sure my Group Buy is complete as it's coming to a close.
Sound like an interesting project 🙂
I would always go with the station Pi pro instead of a separate DAC/RPI stack.
The station pi pro is designed to have two separate stacks with a shielded wall between them.
This will also give you the opportunity to add a USB input via an amanero.
Indeed I will go for the StationPi Pro. I have decided however to limit the project to a streamer (not an integrated streamer-DAC) as I believe that ESS is not the DAC for me.
Yes 3 balance boards for for each pair of caps. Don’t look at this any different than 3 pairs of balanced caps joined together to give the voltage needed as it is as simple as that
Many thanks. I'm not up2date. I barely familar with any Ian products in the last two years, so with things constantly changing it's better to be safe than sorry.
I'll order 3 UcBalancers.
Nice doublers BTW.
Fantastic project, well done!!! LOVE the case design!hello
i have completed the streamer case.
I made one more case for the uc-pureIII for power.
I have connected all the wires needed to make it work.
I haven't mounted the raspberry pi module yet.
For now, it only works with eRED-mod.
It works perfectly with roon, tidal, and qobuz.
I put in power and wait for the SC-PURE clock to warm up.
Music is more realistic and fine details come to life.
Comparison of the CCHD957, NDK2520SDA, and sc-pure.
sc-pure is the best for fine detail.
The control buttons on the MonitorFi Pro have been moved to the back.
There's still a little more work to be done, but I'm happy with the sound quality.
FifoPiQ7
TransportPiAES (sc947-02lf)
HdmiPiPro
ScPure 45,49
UcPure III
MonitorPiPro
Thanks! Thats the base case for my 2 case streamer/DAC. That bottom case in on 24/7 powering just the clocks to get the best performanceMany thanks. I'm not up2date. I barely familar with any Ian products in the last two years, so with things constantly changing it's better to be safe than sorry.
Nice doublers BTW.
Although for some time I have been ogling Ian Canada's modules and ploughing through this bounteous thread, this is my first post here. I think I am ready to take the plunge, and to start with a streamer with I2S output, for which I would use the RPi4 that is now in my Pi2AES.
Before ordering, I would appreciate any comments on my current shopping list:
I thought to use the StationPi Pro to facilitate putting it in a box later. I have a good 5V LPS available (Paul Hynes).
- StationPi Pro
- FifoPi Q7
- HDMIPi Pro
- PurePi II
- 2x batteries 18650
- UcConditioner 3.3V
- 2 ultracapacitors
Newbee question: is it correct that all RPi based DAC projects here are actually integrated streamer/DAC combo's? If yes, would that bring SQ benefits compared to using a separate streamer, due to shorter/simplified connections? No need in that case for an HDMI/I2S cable for instance.
Today I ordered above modules for a streamer from Audiophonic.
Question: are the stock clocks on the FifoPi Q7 of the 45/49 variety? I could not yet find the answer.
If yes, is it possible (for DSD-only use) to replace only the 45 one by an SC-Pure 45 clock?
If no, would the combination SC-Pure 45 and stock 24 be a problem?
A question about ES9038Q2M Dual Mono II DAC... According to the spec there is +/- 11% matching accuracy between chips - are the channel output levels corrected so they match? Perhaps by "auto level calibration" feature?
No response so I assume that DAC/channel output level correction is not implemented. Anybody noticed a imbalance between channels when using ES9038Q2M Dual Mono DAC?
Question: are the stock clocks on the FifoPi Q7 of the 45/49 variety?Today I ordered above modules for a streamer from Audiophonic.
Yes, The supplied clocks are good 45/49. No need to upgrade unless for SC-Pure clocks.
Yes, it is possible. You can upgrade with only one SC-Pure 45 and keep the other 49 one.
You have no problem combine SC-Pure 45 and a 24 clock as long as you have a FifoPi Q7
Please Drive, Can you tell me or you buy the Plastic Nuts and the copper washer,thanks.Yes, I only exclusively use Plastic Standoffs and Plastic Nuts for all my Ian gear
I have news on this issue. If I remove Rpi4 from the stack, MonitorPi Pro works flawlessly.
My whole stack is the following:
- Rpi4
- ReceiverPi Pro II
- FifoPi Q7
- TransportPi MKII
- MonitorPi Pro
In this case the MonitorPi stops receiving remote control signal if I switch to HDMI or Rpi4 input with no signal.
If I put MonitorPi onto a Rpi4+ReceiverPi mini-stack, I get the same error.
The only way for issue-safe working is to remove Rpi4 from the stack.
Can anyone test it for me?
@melorin
MonitorPi Pro remote control trouble shooting:
Thank you for keep reporting the problem. I finally duplicated the issue on my system. But it has no business with FW.
The reason is that the IR signal (pin22/GPIO25) is also passed to RPi to for possible software control. However RPi may not initial that IR pin properly if the IR plug-in software is not installed.
In this case the IR signal might be affected some how because the wrong logic levels. I have two solutions for you:
1. Software solution
Edit the config.txt file on a PC using a SD reader, add and copy the follow line as a last line to the file, then save it.
gpio=25=ip,pu
2. Hardware solution
If you use a GPIO extension KIT, please bent or cut the pin22 (GPIO25).
Or if you install the MonitorPi Pro to the non-isolated GPIO of a FifoPi, please bent or cut the same pin.
Please let me know if you have an update.
Good weekend.
Ian
That looks really good🙂hello
FifoPiQ7
HdmiPiPro
ScPure 45,49
UcPure III
MonitorPiPro
I am just curious, since I am working on my own enclosure, but what radius do you have at the cutout for the monitor Pi pro?
Did you use a 2x2 mm chamfer after that?
Did you anodize all panels after manufacturing?
Thanks in advance 🙂
T
is it a bad idea to cut the pin22 on the MonitorPi Pro instead of Rpi/FIFO?
@iancanada Thank you for the info!@melorin
gpio=25=ip,pu
Good weekend.
Ian
Thanks in advance 🙂
Aluminum 8T plate machined, hairline, and silver anodized.
https://www.engineered.ch/products/ered-mod/Can you elaborate on the eRED-mod Roon bridge capabilities? Any web based management for configuration? Which are the max capabilities detected by Roon and which are the actual usable with FIFOPI-Q7 (PCM/DSD native/DoP)?
I would expect it to be far better than a RPI for audio purposes and this looks to match your observation so far.
I have noticed this board in the past, however there was not much information available for it and therefore refrained from ordering one.
You can get information from the manufacturer's webpage.
I only connected the I2S output of the ERED MOD to FIFOPI Q7.(12,35,40+gnd)
The same board is used in the ch-precision C1, soulution 330.
digital Media Renderer for stereo audio
UPnP AV 2.0 / DLNA
playing and decoding common audio formats from HTTP streams
2-channel asynchronous endpoint for highest quality digital audio stereo playback
bit-perfect, jitter free data transmission
PCM up to 32-bit resolution, sampling rate up to 384kHz
support for DSD64, DSD128 and DSD256
support for gapless playback
ethernet interface and I2S/DSD digital audio output
hardware mode for easy operation
SPI interface available for extended features
compact design, low EMI
I documented my UcPure build in the Power Thread as this thread is too fast-moving and a General Thread.
https://www.diyaudio.com/community/...epo4-battery-power-supply.327105/post-7494588
Hopefully, in time, I can document a 15.5V UcPure/UcBalancer Rig as that is sorely needed. Along with adding resistors to build a 12V UcPure/UcBalancer Rig.
I still need to track down the Nylon I used to buffer the Cap Body from the UcPure for documentation completeness later in the week and I'll try to remember to include the Medical Grade Mean Well AC/DC as it's top quality :
It would be a good idea as long as you can do it.T
But I would suggest try the software solution first. It could be the easiest way. Just to edit the SD card.
Ian
Rijd alstublieft, kunt u mij vertellen over u de plastic moeren en de koperen ring koopt, bedankt.
Rijd alstublieft, kunt u mij vertellen of u de plastic moeren en de koperen ring koopt, bedankt.
- Digital Line Level
- Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
