PO89ZB, an inline DC filter for SMPS wall warts. Preamps, HPA, Korg NuTube, etc
I had originally built my B1 buffer in this enclosure with a small toroid and LM317 regulator. A month ago I decided to move the B1 to a different enclosure and put a different circuit in here. Which required an external power supply connected through a barrel jack. Well, the new circuit was just a little too cramped for my liking so I put the B1 back in. I decided to stick with the barrel jack as it allowed me to use a low voltage external supply. Which in turn allowed me to use one of those cool looking "halo light" switches. And when I saw william2001 sharing his PO89ZB boards I jumped on the offer. Here it is implemented. I can't hear any negative impact vs using the linear regulated power supply. Thank you, Mark Johnson, for sharing the design with us and thanks again to william2001 for sharing your boards!
Reactions: william2001
If you're interested in switches like the ones below, I found them on Amazon and DigiKey and (especially) Newark, using the search phrase "anti vandal". Beware, >90% of them are not mains rated; voltage too low and current waaaay too low. One common workaround is to connect the wimpy A.V. switch to a pcb like H9KPXG on this site, Intelligent Soft Start on neurochrome.com, project 166 on Elliott Sound Products website, etc. Anti vandal switch controls a second, much beefier, mains-rated switch of some sort (triac, relay, etc), which is not on the front panel.
_
Reactions: KMF
For those who are considering designing their own SMPS filter circuits, I recommend starting with a thorough understanding of self-resonance. As mentioned in post #9 of this thread, the inductors in PO89ZB exhibit self-resonance, and so do the electrolytic capacitors. If you can discover their self-resonant frequencies, you can calculate the (parasitic) self-capacitance of the inductor -- and you can also calculate the (parasitic) self-inductance of the electrolytic capacitor {often called "ESL" here on diyAudio}.
The inductor's self resonant frequency f_SRF_ind is equal to
  • f_SRF_ind = 1 / (2 * pi * SQRT(L_inductor * C_parasitic))
so if you know f_SRF_ind and you also know L_inductor, you can calculate C_parasitic {the self-capacitance of the inductor}
Similarly, the electrolytic capacitor's self resonant frequency f_SRC_cap is equal to
  • f_SRF_cap 1 / (2 * pi * SQRT(C_capacitor * L_parasitic))
so if you know f_SRF_cap and you also know C_capacitor, you can calculate L_parasitic {the self-inductance "ESL" of the electrolytic capacitor}
The good news is, inductor manufacturers usually include the self resonant frequency on their datasheets. All you have to do is look it up. For example, the Bourns inductors used in PO89ZB have a self resonant frequency of 63 MHz, as printed on their datasheet. So now you can calculate the C_parasitic of these inductors. Oh boy!
The not so good news is, electrolytic capacitor datasheets usually DO NOT include the self resonant frequency. You have to measure it yourself.
And the silver lining good news is, it turns out that you can measure it yourself pretty easily. Prolific electronics YouTuber "w2aew" shows how in his video #100, entitled "Capacitor self-resonance measured with an oscilloscope and signal generator". Set up the gear the same way he does, take the measurements the same way he does, and presto! You've got the measured self-resonant frequency of your electrolytic capacitor. Not the estimated S.R.F. Not the rectally-extracted S.R.F. wild guess from somebody you barely know. Not the lazy reliance on third-hand foggy memories, "usually things are sorta in the ballpark between X and Y". You've got measured S.R.F. So now you can calculate the L_parasitic of these capacitors.
And now you can run a precise analysis of your filter including its parasitics, to see exactly how well it removes HF noise and to see how poorly it damps its own undesired resonances.
