Same to me . I do not like it as a decoupling cap.
My main ref Dac has on its analog output stage what I called an hybrid decoupling conf. One voltage has local black Gate just before the I/V while the other rail has another cap model of a different brand as well as the main decoupling cap after the r-core of a different model too. Never saw it anywhere. 2 years of voicing....ahaha.
The old green Nichicon Muse of the 90s with some ESR due to aging were awesome. I keeped some on the dozen of dozen of 10 euros CD players I tweaked second hand ! The new Nichicon green bipolar Muse are surely quieter due to very low distorsion. But the old one must added some H2 perhaps and were almost as good as good as some good MKP (I liked the AMPHOM for swaping lythic DC coupling cap with those old CD players.
The only area where the Silmic II worked fine was in the input rail of the 75xx regulator (low ESR at input pin and resisitive at the output pins of those regs worked really fine with a clever decoupling on the local operational amplifier leg, using the long pcb traces as a resistive behavior (sorta of CRC) !
Pick a version you want to build and make the board from the Gerber files Miro shared 🙂
A good start here,
https://electrodac.blogspot.com/p/dac-ad1862-almost-tht-i2s-input-nos-r.html
A good start here,
I'm at beginning of this project and just collecting all information in order to get best result.
Main AD1862 board which require 5v and 12v. Jlsound board also require separate 2x5v. Vunce AD811 has own
power supply (Vunce/Grunf).
Which power supply can be shared with others?
If we consider that Vunce AD811 board has best power supply, can we use it for powering DAC 12v part ?
Is possible to adjust this board for 5v?
Vout = (1+R411/R412) * Vref (2.5V)Is possible to adjust this board for 5v?
Try changing R412 and R420 to 10K (value on Vunce's schematic for +/-12V approx. is 2.74K) to get +/-5V respectively.
Before changes are made, familiarize yourself with how the Walter Jung/Grunf shunt regulator works and how altering set points affects other aspects of the circuit.
Here: walterjung.org /
Also read through Grunfs threads about his work with these regulators, very good information.
This project had a specific purpose: shunt regulation for AD811 IV on a single compact board to mate with MiroDac AD1862. It was not intended as a general use power supply.
Most of time, the distance between the current output of a dac chip and the next stage (I/V): short is better ( cables and stacked pcbs not so welcomes).
It will be an ideal solution to have usb-i2s interface,dac and iv stages, localised PSU regulation for dac and iv stage integrated onto a single larger board to address the distance and physical wiring woes. However, this will also limit ourselves to the flexibility and freedom of what we are inclined to do here - adventures with various implementations of PSU, IV variations.
I wonder if someone here might know the answer... I got an I2SoverUSB v.III board and the matching external oscillator board from Lyuben. In the oscillator manual/PDF, it says "Don’t forget to cut the external clock jumper on I2SoverUSB board", but I can't seem to locate this jumper on the board or any reference to it in the I2SoverUSB manual. Perhaps, this refers to an older version of the USB board? I wrote Lyuben but thought I would also ask here as I am itching to try this out.
Soren
Soren
Soren, I noticed the same thing. I'll be interested to learn what the solution is.
Lyuben is a reliable responder and a patient support engineer. He's fun to work with, I assume he'll have some type of rationale.
Thanks to Vunce for the beautiful board and support. Powered up and tested all the test points and all measure within expectations. And then a sudden realisation after mounting the board nicely on a piece of aluminium as heatsink - I have forgotten to key into the Mouser BOM list for two caps.... damn. ,😂. Waiting to place my next order and include the two small caps before I would connect to my Dac for music playing.
Note: Although the supply voltage for the AD811 is just below +/-12v, please be reminded that heatsinks are required. These little buggers can get quite warm.
@Vuncethe aluminium plate is 3mm thick and I have not measured the temp using a thermo coupler..but using my hands to feel, I can confidently say it is sufficient to keep it within comfortable zone when I left it powered on for 30mins and I don't need to further do any tests.
I’m not much on writing reviews but someone form Burson reached out to me and asked if I would be interested in one of their opamps to use with my miro AD1862 DAC if I agreed to post my impression on the form. This was an offer I could not refuse. I requested the V6 Classic, but was told that they were not available, so ended up with the V6 Vivid.
I’m a big fan of miro’s DACs. I have built 2 AD1862 DACs and a PCM63. I use the AD1862 in a desktop setup and the PCM63 with my main system. The AD182 was using the AD844 opamp for the I/V and the PCM63 is using a 3 stacked AD844s and the TZ out to a OPA627 buffer with a VRDN PS set to 15V. I have tried several different opamps with both DACs.
These include:
AD797
Sparkos SS3601
TL071
OPA627
AD4898-1
I seem to always comeback to the AD844 in some form as my preferred option. It adds an air to the sound that appeals to me that none of the other opamps seem to have. They have also made me turn my head on a couple of occasions because I thought that there was someone in the room with me.
I have used the V6Vs in both setups. I will say that they sound very good with AD1862 in the desktop setup. The V6Vs offer very good separation and focus between instruments as well as realistic tone. I find it to be better in the area of separation and focus than the AD844. In my main system the V6Vs exhibit the same effect, but the air and wide soundstage that the AD844/OPA627 exhibit is my personal favorite. Even though separation and focus is not as good.
I'm working on the Vunces AD811 I/V and if I can figure out what is wrong with the power supply all bets are off.
These include:
AD797
Sparkos SS3601
TL071
OPA627
AD4898-1
I am currently testing another AD844 based I/V iteration, having built numerous iterations up to an 8 stacked version, with numerous iterations on the theme. What does Vunces AD811 I/V look like?
Question: How much different would Vunce's 811 I/V topology sound if used with a more conventional power supply, assuming good filtering and supply cap values, rather than the Jung/Grunf supply. Is it an incremental difference or a huge difference? Objective opinions please if you have them, not confirmation bias. Thanks........I'm working on the Vunces AD811 I/V and if I can figure out what is wrong with the power supply all bets are off.
I would think this is the last op amp IC IV stage I would try on my AD1862. I tried Opa1655 , Lme49680, opa2604 using dual to single adaptor board and single op amp like opa604, Ad844 dual stacked, Ad797, ada4267, and lately Opa627. Vunce's IV using AD811 is staying with the Dac. In terms of resolution, may not be as good as Opa627 but the AD811 sounds warm, full bodied especially in the mids and the bass is tight and goes deep. Thanks @Vunce
*Pardon the messy set-up. It is for a test run and will eventually case the Dac.
- Digital Line Level
- DAC AD1862: Almost THT, I2S input, NOS, R-2R
