Iron Pre Essentials Kits For The DIYA Store - Register Your Interest
Hi, I am wondering if anyone else sees this behavior with their multimeter. I use a Klein Tool MM 700. Today I was adjusting the DC offset of my balanced Iron Pre build. When adjusting all four pins, whenever I get to 0.6 mV and make a further adjustment, my meter goes to 0.0 mV. I can never seem to get anything more precise than 0.6 mV. It always jumps to zero. I am assuming that this is a function of my multimeter, and that the Iron Pre doesn't magically have perfect offset once you get below 0.6 mV.
Does anyone have a recommendation for a not too expensive multimeter that does not exhibit the same behavior?
Don't kill yourself if you can't find a shaft-type solution that's easy for you.
small L bracket drilled with stepped drill, 6mm Dia bar or M6 threaded bar - both from hardware store; cut with angle grinder or hand saw or nail cutter :rofl:
if there is no 6mm couple element, one can connect extending shaft with pot shaft with piece of petrol/rubber hose of 5mm ID
as proper 6mm guide for front hole - one can use disassembled front of bad pot
Reactions: Ixnay
Have you tried taking the meter off Auto and using the Range button to set the smallest V range? That might do the trick...
I believe in autorange function, while measuring mV only if there is rotary switch position for mV
as you have just V position, try manually changing range (press button), as 6L6 said
Thanks, Good idea, but even when setting the range manually, it jumps from 0.6 to 0.0. Oh well, I guess its a fluke of the Klein (sorry).
Good morning IPA- builders,
my backplate arrived yesterday. Made a little nightshift. The story continues slowly, but constant....
Cheers
Dirk 🙄
