MA5332
MA5332MS card with power supply, ordered! 🙂
I will be able to put it in competition with my connected MA5332 amp.. https://www.diyaudio.com/community/threads/class-d-amp-photo-gallery.87913/page-105
wait and see !👍
I compared the two MA5332MS cards...
I modified my first amp (wifi) to add an auxiliary input in order to be able to try the 2 amps on the same dac.
Dac Dual ak4493seq (excellent!!).
Well I prefer...The amp card with integrated power supply.
The sound is more detailed and natural.
The power is not lacking and it stays clean!
For a 5.1 project !
Interesting. cheaper than the board with a separate power supply.
Can you tell us some details? The opamp used, the feedback loop as discussed here before?
The op amp is an ordinary JRC4580.
They used chemical capacitors on the inputs, maybe better than the ceramic capacitors on the pillor board.
For the rest of the principle of feedback...I don't know...
This power supply card is attached to the cooling box, I'm afraid of doing stupid things when dismantling and damaging the thermal pad of the MA chip!!!
The power supply must also play a role, the EMI filtering seems well designed, it occupies 2/3 of the card.
The least fun, it comes without connectors ...
Jst -VH 3.96 with 3 pins, middle pin not used.
The Chinese dual ak card uses the latest model akm4493seq chip in current production, it is an upgrade of the old ak4493 produced before their company burned down.
The JLS card may also have the latest chips because the old ones are no longer produced...Or they are old stock.
The least cool thing about this card is the pops when turning it on or off... output relays would have been needed after the op amps.
You have to remember to turn on the DAC first and then the amp...and the opposite when turned off.
