The big 15 inch fane in Stock again?
Saw it now on the Fane website and at reverb dot Com. At reverb for 163 euro
https://www.fane-international.com/view-product/SOVEREIGN-15-300TC
You can get a magnet of the same size for the 15-300tc for 18€.
You can expect +1.5db more efficiency. So reports Troels Gravesen for a speaker project.
At magnet max company
Ringmagnet Ø 156,0 x 56,0 x 20,0 mm Y35 Ferrit
brilliant news !!! thanks !The big 15 inch fane in Stock again?
I decided to try open baffle with them.
Two boards 120x60 and 120x50cm
Will put two together with hinges. So I can angle one of them to boost certain frequencies. You can see that here.
Maybe I will add two 38cm bass drivers with some inductivity in series.
https://www.diyaudio.com/community/threads/corner-horn-meets-open-baffle-cfa.398842/
That's the archive section I'm afraid. Some distributors may still have a few NOS available though.The big 15 inch fane in Stock again?
Will take some pictures of my system and post it for sale hopefully within the next week or so, the 15-300TC are a lot of fun and very dynamic but it is time to move on. Ordered a reasonably priced CNC machine that will be arriving shortly, need to tidy up the space and get rid of some things.
I wonder if my youtube video contributed to increased sales of the 12-250TC, have noticed it is linked on Thomann.
In the next system I will most likely go back to a 3 way setup. Leaning towards a CD/horn combo with a 8-10" mid and some 18" for lower frequencies, nothing is decided in terms of components.
Here's the ad for the setup in case anyone wants to have a look. It's in Norwegian.
https://www.finn.no/bap/forsale/ad.html?finnkode=316528593
Fane 15 300tc in open baffle project and added bass with Alu foil without crossover and a movable sideboard for equalizing middle tones and bass.
https://www.diyaudio.com/community/threads/ultimate-open-baffle-gallery.123512/post-7437970
The one for the 12-250TC? I never made any for the 15-300TC.Can you give a link to your video on YouTube?
Ah, yes. Well it was fun while it lasted.That's the archive section I'm afraid. Some distributors may still have a few NOS available though.
Now listening. Bass will get some inductivity.
The Fane will be aluminized. Can't listen without on the long run.
Fane Sovereign 15 inch with aluminium foil
https://www.diyaudio.com/community/...loudspeaker-sandwich-cone.402917/post-7455936
The whizzer cones will be aluminized, too.
The bigger one with household foil the smaller one with thin foil from the goldsmith
Unpacking / unboxing Fane Sovereign 15-300tc aka FC-152F01-TC
Small whizzer cone with thin alu foil covered
https://www.diyaudio.com/community/...loudspeaker-sandwich-cone.402917/post-7459180
Now listened to the big Fane with aluminized small whizzer cone:
Just with only this treatment (not aluminizing all surfaces) the sound from the 15-300tc driver becomes more convincing.
As the high frequencies become more articulate everything profits from these better transients. The sliding guitar on Ry Cooders Paris Texas album sounds perfect. Amplifier is a small TDA2004 converted to current feedback.
Double Magnet same size for Fane Sovereign 15-300tc aka FC-152F01-TC, approximately + 1.5db to be expected. 18€ per Magnet y35 quality from Magnet Max germany
- Full Range
- New 15" full range - FANE
