Babelfish XA252 / Babelfish XA252 SIT / Babelfish XA252 SET
When testing outside the amp, you still want to ground IN+ and IN-
Also, have you altered the PCB in any way - the GND solder puddle looks different to the 2 pads above?
Question, I've stared at and compared schematics and need clarification.
I am building mosfet output version. I see R29, 30, 39 and 40 as 470R. I do not see them excluded for the MOS out stage in the notes on the SET version schematic.
They also are not listed in the contents list that came with package. I'm sure I'm missing something here,
but I'm not finding explanation in thread.
Also confused me, R53. There is a R53 location on the board. It is shown as 18k on the SET schematic, but shown as one of the 3 watt MOX resistors on the MOSFET version. With the MOSFET version, what goes in the R53 place?
BTW, tracking worked all the way to delivery!
Russellc
Russellc
post #624 - you have separate schmtcs for all 3 options - full mos, SET, SIT
R29,30,39,40 are smd resistors, already on pcb, part of current mirror biasing network
R53 is part of Schade circuit, populated only if you're building Schade/SET option; it is "just" ommited from schematic for full mos option, same as several other parts
babelfish-xa252-sch-png.1120728
Reactions: Russellc
I have all the "resistive" components almost finished. Caught myself mixing up a 100 R with a 100K resistor. I will post board pics as soon as done, more eyes the better. Problems are much better caught before fire up!
Hakko 951 is working excellent, good replacement for the old 929. "Sleep" mode is a little irritating, beeping all the time. Usually leave this off.
Russellc
Zenmod, or anyone, are there any pics or descriptive info on the HA boards? Appears larger ones are for power supply? I was going to use teabags power supply board, got the optional HA boards as I always get all parts available! Surprise, maybe a PS board?
Thanks in advance. Will post board pics tonight after double checking my work.
Russellc
