The Catharsis Music Magnifier, The Elusive Hexfet CFP from spice fantasy to PCB
Do not convert your circuit, as you will apply 6 pin socket, it will be ready for any jfet. I find strange that with 2n7000 I had lower distortion 4db higher loop gain and higher slew rate. With BF862 I had to reach 7.5ma bias to get back 1kv/us and 100db NFB @20Khz.
To run with +/-36v supply, I decreased the CCS 330ohm resistors to100 to lower the dropout to 1.5v. I have now 30vp 1khz 0.00007% THD always with a gain of 34.
MOSFETs at low currents are perfect square law transfer function, that is the transconductance increases linearly. When used in differential mode, it results very linear.
For 2n7000, noise is not specified, different brands differ.
For this project im not interested in using a mosfet input pair. That said, your build is yours.
Experimentation will continue when pcbs arrive on wednesday.
And excuse me I see now you were talking about the input load CCS's. Reducing those resistors does reduce VAS current and may increase thermal drift. Should work anyhow.
To respect your idea, I am not using MOSFET but jfet as you prescribed, only I chose cheaper BF862. The CCS resistors need to have 100mv min, as I increased the bias current 9ma to 15ma, 100 ohm gives 750mv. The VAS current is increased by 100 ohm common resistor to be 3.750ma for each VAS, maybe 75 ohm will be better. It decreases the positive dropout to be equal to the negative one. I adapted to my autobiased OPS without touching the compensation. I get without feedback 0.27% instead of 0.3% standalone I don't know why, full feedback it falls to 0.0006% keeping perfect square wave. I am gratefull to ingenious ideas that will alow me realize my last analog amplifier.
Reactions: Rupopulles
Dear Hayk, you seem to know what youre doing indeed. In the end its the voltage over the resistors that matter; thermally speaking.
Interesting getting 0.27% instead of 0.3%. Is that with the exact same voltage over the load? Your front end does have some output impedance perhaps that affects the OPS a bit.
Be very suspicious of BF862 counterfeits. They were very nice FETs but obsoleted. We had to redesign a product that relied upon them. There was an industry-wide scramble to find remaining stock, so I'm very skeptical about your source.
P.S. This is the part we eventually made work. Performance seemed very comparable, but the application was not audio. https://www.onsemi.com/products/discrete-power-modules/jfets/cph3910
That's my recollection as well. The Onsemi part was not as thoroughly characterized for noise performance, but on the bench seemed very good competition. We used it from about 50kHz up to about 30MHz, but I bet it was comparable at audio frequencies.
For ultra low THD and finely tuned compensated input stages , small area is the key .... (below).
SMD is the only way , and futureproof. So many more choices in SMD .
Thank you for inspiring me to resurrect a similar design to the "catharsis".
OS
