Hornresp
Gentelman,
Tapered TL example.
How to understand Fr1 Segment 1 and tal1 practically?
Let's say I have 20-30mm sheep wool. Only overall stuffing weight matters?
  • stuffing_test.txt
    stuffing_test.txt
Reactions: Kravchenko_Audio
Others might suggest too but as there is a little residual ripple, you could try incrementally adding fibre up to say 75% of the line length until you achieve an optimal response. you could build the enclosure using this amount and tweak to your listening taste or measurements. I found it needs a bit of iteration.
The TL design wizard give several different starting points. Using the MJK2021(A) as an example attached. You can play in the loudspeaker wizard with different values to see the effect of changes. The Brian Steele 2022 method looks nice but in a bigger box.
Screenshot 2023-06-14 at 8.04.48 pm.pngScreenshot 2023-06-14 at 8.02.20 pm.pngScreenshot 2023-06-14 at 8.00.56 pm.png
In the test example, 64% of the length of segment 1 (starting from the closed end) is filled with absorbent material having an airflow resistivity of 882.50 mks rayls/m.
METHOD 1 - Given absorbent filling material airflow resistivity and density data
A quick Google search reveals that the airflow resistivity of sheep wool varies greatly, depending upon the packing density:
Wool with a density of 10 kg/m^3 has a resistivity of 500 mks rayls/m.
Wool with a density of 100 kg/m^3 has a resistivity of 15000 mks rayls/m.
As a starting point, assume that the relationship between the wool density and airflow resistivity is linear so that for a resistivity value of 882.50 mks rayls/m the density is:
10 + (882.5 - 500) * (100 - 10) / (15000 - 500) = 12.37 kg/m^3.
The absorbent filling material in segment 1 has a volume of 32.148 litres [*] which means that the material weighs 0.40 kg if the density is 12.37 kg/m^3. The weight of 0.40 kg is a little less than the 0.518 kg shown for an equivalent volume of Polyfill, which means that the wool weight is probably about right given that it is likely to be less dense than Polyfill.
The simulation will show how the response is affected by adding filling material, but in practice the accurate flow resistivity value of the material being used is unlikely to be known. Most users just progressively add or remove filling material until the desired response as simulated is obtained.
[*] While the value is calculated and used internally, the volume of absorbent filling material in each segment is not currently displayed as an output. If it is not too much work to add, it will shown as an output in the next update.
METHOD 2 - Given Polyfill weight data only
Use the Polyfill weight as a starting point regardless of the actual absorbent material being used, and progressively add or remove filling until the desired response as simulated is obtained.
METHOD 3 - Given no absorbent filling material data
Progressively add or remove filling material until the desired response as simulated is obtained.
Reactions: woodo
There was a guy named John Cockcroft who did a series of very stuffed transmission lines in Speaker builder magazine in the early 90's. I lost all of mine due to water damage. I have some back issues to look through.
I remember that he really stuffed them. Pretty much akin to mineral wool densities. If I remember the underlying mechanics you are slowing down the sound transmission speed through the fibrous tangle and effectively increasing line length.
Jacek you know my contact info if I can help.
Mark
Stuffing does not have a significant effect on the TL's Fb. A lot of stuffing in the box does severely reduce output at the vent however. It's no wonder that older so-called "classical" TL designs usually called for the use of drivers with higher Qts.
Right on all counts. I have a paper somewhere that actually measures vent output of a maximally damped enclosure. I will try a dig it up. There's never a free lunch. But there is making a driver to things better in different ways. The Speaker Builder articles were always using inexpensive Radio Shack drivers. So I'm guessing high Qts and weak motors. In effect a over grown variovent alignment.
Mark
Reactions: Brian Steele
in the following example, what are the Ra and Xa values at the Marker Line actually pointing to ?
as I would have "thought" 🤪 the values would be 0.8 chart value multiplied by the multiply factor of 0.7537 which would be about 0.6 ?
Hi deanznz,
Thanks for the feedback. The Ra and Xa values should be as you say, so something is definitely wrong somewhere. The interesting thing is that the values for the test designs I checked are all correct. Could you please export the record you are using and post the data file here, so that I can replicate your results and hopefully track down the problem.
Kind regards,
David
If we hover over the vented box port details (Ap/Lpt) we get the air mass and end correction, and helmholtz mode freq, which is fantastic!
Is there a way to get that type of info displayed if using the upper section(S and L inputs ) so that tapered TL shapes, etc would yield similar info ?
thanks David
Hi Bw,
Unfortunately, no.
The Ap and Lpt parameters specify the cross-sectional area and axial length of the cylindrical port tube in a bass reflex type loudspeaker, which is why it is possible to calculate the internal end correction and Helmholtz resonance frequency values.
A single segment or multiple segments could certainly be used to specify a "bass reflex port" in a front-loaded horn system, however Hornresp doesn't know that is what the segment is being used for, and in any event cannot calculate the throat end correction and/or Helmholtz resonance frequency for anything other than a cylindrical tube connected to a chamber.
While it is possible to calculate the air mass in a segment by multiplying the segment volume by the air density, I am not sure how useful that information would be in practice.
Kind regards,
David
Reactions: Booger weldz
No need to post the record thanks, I am pretty sure that I have found the problem - it will be fixed in the next update.
Just to be sure though, could you please confirm that your record uses stepped segments and/or is a CH2, CH3, OD2 or paraflex horn type configuration.
Hi David, It is Not playing up today, I "think" I was using an OD record (on Con or Exp) then changed it to Nd when I noticed it was not reading correctly. I do Not think I was using stepped segments on that Record, but quite possibly on other records around the time.
I do have a low priority request, can the "Compare Captured" be applied to All graphs ? or have the option to be applied to all graphs.
cheers.
Hopefully the changes to be made in the next update should fix the problem, one way or another.
What are the charts that the feature is currently missing from?
As far as the loudspeaker wizard is concerned, pressing Ctrl+C when the power or pressure response chart is displayed captures the current results. Pressing Ctrl+V shows or hides previously captured results. Results for all loudspeaker wizard charts can in effect be captured by re-setting the baseline by pressing Ctrl+Alt+B.
If no unforeseen problems arise the functionality of the existing Compare feature will be modified in the next update so that selecting 'Compare Previous' / 'Compare Captured' / F4 will add the comparison traces to all six main charts, not just to the one currently being displayed.
Thought I'd write another thank you to David!
Here's a modelled vs measured comparison of a 1.72m exp horn path pair I'm building at the moment.
Test rigged in workshop - not ideal measuring space, but hey!
Note the bucket raisers.. give 26cm space for SPL to escape.
2.15m total height!
The modelled design, with driver, Eminence Kappa 12A.
The measured result
Not bad for a workshop measurement. I'm actually really pleased with this!
Performs exactly as modelled really.
This is with no XO just horn cutoff etc.
Cranked up test sweeps always seem soooo LOUD! Could probably try even louder but it drives the wife mad😂
More to come yet I think, as bracing, damping and backbox volume tuning is done.
I love Hornresp!
