Spooky and Hellraiser SMD 60W amps (Wolverine compatible IPS)
It would be nice if you could use some form of revision control on your drawings/sims, so others can keep track of changes.
I took your latest Symasui 2.0 and modified it, to use for the AWH-048 form-factor design, so that it can be tested in a real situation.
Set the gain to match the original Pioneer design.
In the original design you posted, I saw some ringing on the negative edge and peaking on the frequency response curves?
The ringing gets worse on my implementation.
If you let me know the components you selected, I could add them to the sim as notes since I assume we do not have models for them.
See what you think
I see you use MJL21193/4 - slow , some Sankens are 60mhz ! the 2 diodes should be between VAS LTP bases.
Your NFB resistors are too high value , more noise.
I might go your way and use the dual TTC004's in the VAS cascode for through-hole. Matching does not matter
on this cascode , it's just a high Z level shifter ... isolating the BC's from HV.
I'm "post OCD" on the sym ....
I do see that bit of ringing with SW or heavy clip. But , it is is well damped (stable).
MY simulation is in the zip - 1/2ppm !
OS
  • Symasui V2.0.zip
    Symasui V2.0.zip
Reactions: Hipocrates
I do, among other vintage units. I'm trying to wrap my head with how it would sound with such a mod, it is an amazing unit as it is
I'm going to mod an OEM amp for these projects , using a old Sampson servo 500 chassis. But it has strait , flat standard 3U heatsinks.
How it would sound ??? Airy , effortless (with a big OPS). This small OPS would likely sound better than say a "Rockville" scam "3000W"
studio amp. For a bigger OPS , Wolverine OPS's will work with these designs .. Stuart made a 4 pair version , "Fireanimal" runs 4 pair
MT-200's and gets sub PPM @ 400W !!
OS
Yeah I had the clamp diodes wired up incorrectly, fixed.
Since we are using the exsiting sx-1250 infastructure, we are forced to use the slow MJ2119x or original 2SBxxx/2SDxxx devices. Will try to make the best out of what we have to work with.
We could reduce the NFB and input impedance a bit (47k) and still retain the same gain
I just chose what they used originally since they want a high input R(62k)
OS
I have the wolverine boards, impressive work, i got them just more for curiosity and for learning, especially since I realized that I don't need another behemoth. I will rather go with the symasui... I like your approach very much, a sleeper unassuming amp sounds like fun!
It's done ... time to OCD it !
Such nice short direct traces .... I am confident this will beat the Wolverine.
Device quality will be the deciding factor here.
Offset trim is in the "classic" way. Trim a few ohms LTP Re to zero the output.
Most Bourn SMD trimmers are 5 turn , just a 1/4 turn to compensate for that 1% Hfe
difference in these integrated dual PNP BJT's (BC807DS).
OS
Not so short, NFB trace is quite long. I prefer NFB trace as short as possible.😉
R20 to Q5 = 20mm ? That's long ?
I see where you could say ALL the NFB traces are long , NFB goes the whole length of the OPS board.
I was passed over on the wolverine ... good ! I use that thread to see what 20K$ fancy test rigs find out.
What I found out , i recycle in the "post wolverine " design.
On this IPS , it's a VFA - just 1mA through R20/21. High Z Q5's trace is just near the clamp diodes and cascodes.
On the CFA , 80mA is way more. On all , I only allow reduced signals to pass anywhere near any high Z circuitry.
I keep those big CFA resistors away from anything and put them near the VAS/interface socket.
It works out good , Wolverine is 1/2PPM at 100's of watts.
I have to do the CFA Hellraiser again (next). I will isolate those pesky big resistors and even make the CFA ground selectable
between G1 / G2. Then during testing - finalize it. I use solderable bridges to do this. Those bridges are under Q8.
I will use another dual BJT P/N package for Q7/8 on the Hellraiser.
OS
You nailed it , Printnik. I guess I'll have to figure out transfer functions !
My simple 2- pole does not oscillate , but your method gives a whopping 90db OLG @ 20K without oscillating.
I'm going to hold back on the Symasui and get the two originals done (below).
I'm finally at the point where I was before my HDD failed.
OS
Reactions: inyashd
