Iron Pre Essentials Kits For The DIYA Store - Register Your Interest
Yesterday evening I tried to figure out what prevents the negative phase buffer to get any input (when K6 is in "SE mode" = preventing output to get to the output transformer). I need to try again. But to find out the schematic to look at is the "input relay" schematic (which shows K1 - K5)?
for SE input, neg buffer's input is by default grounded ( short between input pads 1 and 3) and K6 is energized, so cutting connection between neg buffer output and neg phase coil of autoformer
K6 coil is together with all input relays schm
K6 contacts are together with input buffers schm
Reactions: MEPER
Sorry for deleting previous post... this forum is too quick. :joker: Here's an updated pic re: K6.
ZM - Noted with thanks as always. Most folks have never seen the previous schematics / boards. I ooked. Same things, but I didn't want to cause any more confusion than I normally do. :joker:
Reactions: ranshdow
@MEPER - I think there was discussion re: steel vs. aluminum top / bottom panels. So... I am not trying to avoid the question, I just don't know. Also, what's true today, may not be correct tomorrow.
For everyone - Someone that ordered a chassis one or two weeks ago may get a different one than you order. The chassis sold in the store may be different too. Any changes are likely to be minor, but who knows? What I do know is that Gianluca is incredible to work with... and even if the prototype chassis is not exactly what you want, Modushop can likely get it exactly the way you'd like it. The "uniqueness" comes from the artwork, IMO. That artwork can be applied to any chassis, I would guess. See MEPER's great example a page or so ago.
I love that some people are anxious to get their hands on a prototype version and maybe even tweak it a bit for their own needs.
I just updated post #1 to reflect... the chassis is in development. For specifics of your particular order, ask Gianluca. The team working on the chassis has not chimed in often (for good reason). It'll be here ... when it's here. Details will be posted when it's finalized.
Until then, I can't wait to see some of them with full builds inside. 🙂
:cheers:
Ok, steel covers........I ordered a base plate which is steel......so "at bottom" I am safe 🙂
The "Donut" has steel cover......stainless steel......it is not as not as good as "real" steel or course.....but still trafo has magnetic shield......so I think I am safe with alu top.
If Cinemags output transformers makes trouble......I will do the "mu-metal trick"!
Also, both slim line and galaxy. Slimline are all the same width, but a few different depths are listed
For clarification... directly pasted from post #431 and depth added to post #1 as promised. Emphasis added is mine.
@6L6 had us produce two versions: the first one is on a Slim Line 2U while the second one on a Galaxy 383.
  • Slim Line 2U: 435 (W) x 80 (H) x 170/230/280/350 (D)
  • Galaxy 387/383/388: 330 (W) x 80 (H) x 170/230/280 (D)
  • Thank You
Reactions: Dennis Hui
Aha, bold numbers....thanks, either is plenty big for me. I sort of prefer the Galaxy series of cases.
Russellc
I ordered the Galaxy 388, 330mm wide x 280mm deep, with all the modifications for a SE chassis. I also had a custom drill pattern done in the bottom to mount boards, which required selecting aluminum top and bottom panels. Haven't it gotten it yet.
