Best Compression Drivers today 2022?
Which is a recipe for awful sound quality, in my experience.
Yes and not necessarily. There are 2 advantages of such large format horns:
  • Theoretically perfect directivity
  • Huge 'sound'.
The main drawbacks are astigmatism, throat distortion and diffraction-related side effects. A strip of 30ppi open cell foam with a thickness of about 2 cm in the slot opening works wonders.
very nice!
BTW should I dare ask what you thought of the Klipsch Jubilees?
You go first... 🤣
The worst sound of the show. Embarassingly bad.
Seems that it's using Axi2050?
Joseph Crowe just released a video about Axi2050.
Similar conclusion from his previous measurement/listening impression.
Is the treble part that's where the problem is?
In his review after exceed certain SPL the upper part performance degrade quite a bit and didn't hit his target.
The wooden MR94 was built by a Japanse guy. He initially used the BMS 4592Nd and later switched to a Selenium phenolic driver + ST400 tweeter.
is the phenolic chart very different from a plastic chart in terms of sound properties? vintage compression drivers used a lot of these.
Icône de validation par la communauté
You mean the material?
Phenolic diaphragms are made of fabric (linen) hardened with a specific (phenolic) resin. Basically somewhat similar to soft domes.
Most phenolic compression drivers don't make it past 10 kHz, but they usually sound very good > notable examples are the JBL and Community drivers.
Everything was wrong.
Tonal balance first and foremost.
Think cheap PA sound.
The polar opposite of the refined, smooth and lush sound that top-notch large-format drivers and horns can produce, if done right.
For those who are not familiar with compression drivers, it may be useful to draw inspiration from existing commercial products (not necessarily Klipsch).
At least I bought some compression drivers after listening to both PA and Hi-Fi/high end speakers in which they were used.
I really liked the mid/highs of the hi-fi speakers. However, the 8" woofer could not quite keep up with the comp. driver,
making the tonal balance somewhat lightweight/bass shy with some music. Despite the small waveguide the xo point was already fairly low (1200 Hz).
So there seemed to be potential for a combination with a bigger woofer, a larger waveguide + xo point below 1000 Hz, and that's what I did.
ro808
we are talking compression drivers here, and citing Klipsch as a very poor implementation. How to design a proper horn based system is a different thread and the parameters are very restrictive IMO.
Why the Axi sounded so crappy in the Jubi is yet another subject. I suspect the electronics and the DSP are the culprits. Cut all that stuff out, use a passive network and use a tube amp and then we can talk.
Reactions: docali
Folks, it shouldn't come as a surprise that discussions on a forum are biased. In this case, it is biased by my listening to the system. Clearly something that whoever designed the Jubilee didn't really do.
I wonder if you did listen to the Jubi.
BTW I have DSP on my system. I am a dinosaur but I accept technology. Simplify, dissecting and rebuilding the speakers from the ground up is what I would do.
I am still curious about the Axi and the horn combo on the Jubi. People that I respect here have spoken very highly about these so I was really taken aback by how bad the implementation was.
Reactions: marco_gea
If you refer to the Klipsch Jubilee, it "features an external active DSP crossover network".
I'm also using DSP, but fwiw the best systems I've listened to - either horn loaded or direct radiating, were all tube based.
