Imo each has his own tastes, for me, with unaccuracy inmind of the reccording and the playback and just talkiung of the high mid and treble, this video is just showing a non natural sound : too much unatural clarity and ligthness, at the limit of the brigthness and a little in it, imho. Of course it could be the disc reccording as well.
I think it's mostly the room > lots of reverberation.
Noam Geller posted a video of the Lansing Iconics.
From the first notes onwards... I think he's right. This sounds natural.
I built pelnty PA speaker with BMS drivers (1", 1,4" and Coax). I think I know what you are speaking about.I've been alternating the two CDs in my latest experimental build syn11.
The 4594he is the easier of the two to get sounding super on wider array of material.
But on certain material, the dcx464 has a degree of clarity/realistic sound, that I can't quite match with BMS.
On other material, it sounds bright despite measurements that say otherwise...simply dunno why.
The BMS tend to sound "soft" - at least at pretty high power levels (so not in the living room - 1000pax room). Not weak - but a great 2" shows you more precise what's going on on the stage. The BMS sounds more "HiFi" - which is often pretty nice. I thought the very high K2 at high frequencies is probably a reason for that.
My last project was with the B&C DE360 - 1" ring radiator which goes without resonance to 20kHz (but starts right after there). It's membrane is way harder as what BMS is using and I also had the impression of a more detailed, "realistic" sound. But still without metal dome "ringing" and a relaxed presentation.
But I didn't A/B them so this is really just a guess! Don't take it to serious.
There are some conflicting aspects to PA design compared to Hi-Fi though. For example the lower efficiency could be due to increased use of disipative surrounds and back chamber absorption which would improve fidelity. Also a Hi-Fi design could use a smaller gap between the phase plug and dome and a larger back chamber as it doesn't have to be designed to be thermaly limited rather than excursion limited over its full range as a PA driver normally is. TBH I also think classical compression driver design is that complicated, especialy if you accept less than the maximum possible output in the form factor.compression drivers seems new to them, I mean not their core business that seems to be classic hifi oem drivers for living room hifi brands ! I doubt they have the level of the old PA companies with their know how and research budget. Go figure !
One reason for the not-so-high efficiency of the Kartesian driver is probably the low compression ratio. With a 1.4" throat and a 2.56" voice-coil this will probably be below 4. And that would definitely not be a bad thing for HiFi.
Charles
Charles
I'll give you three current products that would qualify as "cream of the crop" out of the box:Ok guys, so where are we now after nearly 59 pages?
Which is the best cd/horn combinations from 0,6-20kHz and 1,2-20kHz? Would be interesting with a reasonable priced option and a higher end proposition. 🙂
TAD TD-2002 (1" throat)
TAD TD-4001 (2" throat)
GT SOUND GSU-D04R (2" throat)
Horns:
Yamamoto SS-500 (1" throat)
Yamamoto SS-300 (2" throat)
I'll let others summarise on the "reasonably priced" options (none of which I can guarantee will be as good as the above).
is it the Kartesian CMP45 ?
https://www.toutlehautparleur.com/u...rtesian-cmp45-vtlhp-8-ohm-sortie-1-pouce.html
Anyone tried ND3ST?
Distortion test from Voice Coil is so low, maybe the lowest I've seen at 104dB.
https://audioxpress.com/article/test-bench-eighteen-sound-nd3st-1-4-compression-driver
CSD plot shows a bit resonance though.
I'm doing 500-20kHz in my own system and it sounds superb... ;-)i don't think it"s good idea to go 600hz / 20K not because of the driver but because of the Horn size .
i had the NSD3N ( nitrided titanium version) with a JABO KH53 horn very good combo from 800Hz flat without correction but needed a tweeter from 10K with this large horn.Anyone tried ND3ST?
Marco what are you using in your system?
JBL 2450J with Truextent beryllium diaphragms + Yamamoto SS-300 horns
Yap. It is really the only reason to go back to Munich next year, kind of pathetic.I think it's mostly the room > lots of reverberation.
very nice!JBL 2450J with Truextent beryllium diaphragms + Yamamoto SS-300 horns
BTW should I dare ask what you thought of the Klipsch Jubilees?
You go first... 🤣
The two systems were physically identical except that the crossover component values were tweaked to yield as close a FR as possible.Could you clarify please, were the two waveguide systems physically identical or were they each adjusted for the driver used? Thanks.
These two systems were then rated virtually identical. Both of these systems were rated higher than two other non-identical systems.
These results are what led me to the belief that drivers make little to no difference - it's all in the system design, not the drivers.
very nice!
You go first... 🤣
The worst sound of the show. Embarassingly bad.
Very nice! Do you know of any modern, say below $500, that comes close? 🙂JBL 2450J with Truextent beryllium diaphragms + Yamamoto SS-300 horns
- Best Compression Drivers today 2022?
