can anyone offer help understanding the flow of this circuit
The first mpsa29 B=14.3VDC has problem, pin B voltage must be near 0V, that's why there is a positive DC in the output
There must be something shorted to a 14.3VDC for the input circuit, according to the diagram the C1 capacitor will block any DC input and the Q1 base pin should be near 0V, please check and find out what caused the DC input
ok Patrick, on 1 of the input pairs i do have 0 volts ....the problem is that since this board has no markings it makes it difficult to know Q1 from Q2 ..but yes, one of the mpsa29 i believe this to be Q1 has 0 volts at the base.....once again thanks for all your help. Frank
It may be better to restore the circuit to its original form before proceeding. However I would first ask as rayma just did, what was the symptom you were trying to fix that started all this parts changing? Was it simply that you noticed a high voltage at the output? If so, did the amp ever work right?
This amp was purchased from a person that was honest and told me the amplifier had 1 channel down. I figured it would be an easy fix but I was wrong. All parts have been put back to how it was when I received it. All the semiconductors wher pulled and check with a dvom and a peak advanced tester. ...the problem is that I still have 59volts at the speaker output of 1 channel......the input pairs Q1 and Q2 have the emitters that are tied together and go connected to the collector of Q3 that connection has 14vdc when it shouldn't be.
