yes that too. its follows the beta=Bl^2/ReI remember you talked about servo effects in low frequency with a strong motor, is it the 4ohm version exhibit slightly stronger servo control effects in LF and thus "corrects" kms(x) better?
The AudioXpress test of the PTT6.5M08NFA01 is online:
https://audioxpress.com/article/test-bench-the-ptt6-5m08-nfa-01-6-5-midrange-from-purifi-audio
Thanks for your insights! Looking forward to your 10 inchs!yes that too. its follows the beta=Bl^2/Re
One small question, any plan to put the new 4 inch NACs on your online shop?
I am working on a 2 meter planar linesource and is on the hunt for some woofers, that can be crossed over to the planar. They will be crossed over around 250-300hz . I want them in a closed box magnet to magnet. Will any of the purifies work well in a closed box , and is possible to hear them 2-3000 euros is alot of Cash. Live in Herlev.
Another one for the front page - DIY Kaimana by Alexander Gresler (Posted on FB DIY Loudspeaker pad)
PTT6.5x04 + SB TW29BNWG-8 in a 16l box with a Seas SP22 PR.
https://www-donhighend-de.translate...aVRrWys&_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=en
we are working on a 33mm long stroke alu dome with wide dispersionHello what type of material tweeter is Purifi looking to go with? Ie. Beryllium,ribbon, etc?
Interesting. May i ask: The frame diameter what size will that be ?we are working on a 33mm long stroke alu dome with wide dispersion
Will it be built in such a way that a third party waveguide can be incorporated?we are working on a 33mm long stroke alu dome with wide dispersion
Waveguides are tricky with wide dispersion large aluminium domes in my experienceand maybe even a waveguide option
- Exploring Purifi Woofer Speaker Builds
