Super Regulator
@grunf Right, I see in the AD797 datasheet that 1k is the highest (unfiltered) input resistor recommended for low noise.
I’ve been able to remove the AD797 oscillations under load in my prototype SR circuit by shunting its power supply pins with a low ESR 100u cap. So now I’m building the final real circuit with AD797 and need to know the best values for the input resistors. On Jan’s diagram, it is 500R on the non-inverting input and a 1k-filtered/1k voltage divider on the inverting input.
Assuming I will use the lowest leakage polymer caps, what resistor/capacitor values would you recommend for R4, R6, R7 and C8, C3? Should I increase R4 to 1k (since it is filtered) and C9 to 330u? Should I decrease R6 and R7 to 500R? And what about C3? Thanks so much for your insight!
@safesphere The problem is not in the noise but in the error at the output of the regulator, for the AD797 I would stick to the value from the original scheme, especially since the AD797 tends to oscillate in this application. The ADA4625-1 is a great replacement for the AD797 and it's also a jfet op amp that allows Walt's upgrade to be used.
Ref #3,015/ #3,018
1.3k now fitted to R6/13
discovered led's installed incorrectly, replaced with new in correct orientation, Neg LED now illuminated..
Zeners all installed correctly,
Voltages
D7 12.1, D8 .2, D9 .2, D2 1.4, D3 .25, D4 .25.
LED Pos 1.4, Neg 1.9.
Op Amp
Leg 2/3 .2, Leg 4/7 27.5.
voltages are 28.5v input to superreg
27.5v pos out
15.7 neg out
What are the voltages on D5/D10? Also, are the outputs connected to the senses? On Jan’s 2.3 diagram, the pins of J2 should be connected 1 to 2 and 3 to 4. Also similarly the pins of J6 also should be connected 1 to 2 and 3to 4.
To make sure my statement is clear, do NOT connect any J2 pins to any J6 pins. The connections should be like this:
J2:
1-2
3-4
J6:
1-2
3-4
The voltage on D2 is incorrect. It should be 12V. Check the polarity of this zener again. Note that the polarity if this zener is different between the positive and negative regulators. This however may be only a symptom of the opamp inputs being out of range.
Ref #3,015/ #3,018
Voltages
Op Amp
27.5v pos out
15.7 neg out
The part numbers are those from Jan Didden's latest circuit in Linear Audio?
@esprit
It will work with these links, but the sound quality will improve if you remove the links at the J2/J6, run all 4 wires from each output to the load, and connect the same wires at the load instead of connecting them at J2/J6. I use twisted pairs: 1 and 4 is one pair, 2 and 3 is another pair. The latter pair (2 and 3) ideally should be shielded and the shield grounded, but it should work even without the shield.
Just for the record, I'm uploading the original latest Didden SR schematic. It will be easier to check all parts and connections above. I don't remember them all.
On my application, which is replacing shared 317/337 on one preamp, and series 7818 + 7815 and 7918 +7915 regulators on the other, I will not have space for separate SRs for each channel. I would have to share the SRs on both channels. As I am not handy with SMD parts that is not an option either.
I haven't yet seen, on the pcb design, how small can I get putting resistors and diodes standing up, but I am not too optimistic. If anyone knows some existing design using such technique, please let me know.
I am sorry that there was a zenner diode with Japanese letter product label included in my photo.
So I post again.
I would like to have advice.
I built +/-5v super reg but negative rail has only -4v output.
I checked resistors again but couldn't find my mistake.
I use 5K for R1,R8
910 for R6,R13
1k for R7,R14
2.5v zener for D2,D7
Q2=BC556C Q4=BC546C
AD817
