There are great sounding and not super expensive 2-way designs. Why go for 3-way, then?
Things dont shaffle around enough with 6" 8" you actually need 12" or 15" to do so . Similarl hor highs. 1 inch is enough . And for mids to stop them from getting coloured with white noice from tweeter and over exertion from low frequencies a seperate mid is important. So three way is minimum. Unless you need a system to just to understand the words . In which case 1 fullrange with high effeciency is enough . I have driven a 99db driver with 1 w amp that can get loud enough to shatter the eardrums
Many hi-end speakers use say 8" woofers, just multiples ones, with higher excursion and good suspensions and motors, to create sufficient bass for most listeners. You wind up with a narrower cabinet (better for diffraction) and better transient response (the physics of "overhang" haven't gone away with large drivers). And bass drivers IMO shouldn't be allowed to get very far into any midrange, so low xover point. So the deep bass is below 100 Hz (really 60-80Hz), dealing with a 15" say for that low range seems very old fashioned when there are alternatives. What didn't exist back in the heyday of large woofers were smaller high-excursion drivers that can now physically move the air required. Agree 3-way with terrific driver selection and xovers integrated has many advantage's. But for near field listening, a good 2-way main speaker can do the trick, with a sub (so that's really a 3-way anyway, just a different design approach than the older fashioned huge woofer, say 6 inch mid, and tweeter).
Well one of the reasons there have been so many variations in speaker design over the past 50-60 years (and still are) is there hasn't been universal agreement on several key aspects of design. So there are the big woofer lovers, and there are multiple smaller bass driver lovers, sub lovers, etc. And dome mids vs. cone mids, the list goes on.
I have used 12" and 15" woofers in designs in the 1970s using 3 cu. ft. enclosures, more recently have enjoyed designs that can produce good, smooth bass to 40 Hz with smaller drivers and enclosures. As we know the sub was developed to get good bass from smaller enclosures, and so the main speakers don't have to be that big. The OP posited that good 2-way designs mean 3-ways may be not be needed. I would make the case that the main speakers can certainly be good 2-ways, and a sub can provide the low bass if you want down to 20 Hz.
I think transistor amps are fine by the way :)
Reactions: 1 user
Increasing the number of ways may decrease IMD but may also increase other issues.
Drivers in separate boxes that are mechanically isolated from each other seems like a rare luxury. Woofers are often off-centre, resulting in vibrations that not only move the box (which could be benign if it's pure dipole motion) but actually rotate the box around its centre of mass. These forces get transferred to whatever else is connected.
Similarly with leakage of magnetic fields. Out-of-band signals are surely measureable across speaker terminals. Whether generated by air vibrations or box vibrations, the drivers will interact with each other, but it's rare to see additional effort to try and cancel or correct for that crosstalk.
Joined 2007
Many would agree with you Adison and these days I think it is simply cheaper and easier to use electronics or DSP for the crossovers, and especially if we are talking about passive crossovers in the very low bass area.
My Behringer cost less than a pair of low DCR inductors to set a bass XO at 80Hz so frugality is important as well as sound quality
My opinion (or bias) is that the approach and design chosen should be based on the key objective(s) and also constraints of the listener. If a key objective is good overall sound at an affordable price and in a smaller room (the cost and space constraint) there are many good smaller 2-ways that can do that. If a key objective is listening to jazz with lots of brass then a 3-way may be the better choice with a dedicated mid. If one likes pulsating bass and has a somewhat larger room with placement flexibility, subs added to 2 and 3 way designs can be a plus. Someone older with reduced high frequency hearing may enjoy certain types of tweeters over others. Someone with a really bad listening room (but that's all that available) may want speakers than minimize reflected sound. Could cite many examples. These bigger picture considerations should come before getting into the design details. There are many solutions available.
Reactions: 1 user
At this point I am only interested in 10-way speakers. I just can't listen to a 9-way, or (gag) a mere 8-way. Imagine asking a driver to cover more than a single octave... why it is just outrageous. A 3-way (eye roll) is not hi-fi... it is not low-fi... it is No-Fi... I had this amp specially made, it goes to 11.
Reactions: 1 users
music soothes the savage beast
Joined 2004
Good old times of kabuki speakers...
Btw, the premise of this thread is there are great sounding cheap 2way speakers out there. I am still waiting for op to tell me what they are and where to get them.
Reactions: 1 user
In lots of ways designs have moved on a long way since then. I was also designing in the early 80s with large drivers and none of them would hold a candle to current ones. I also disagree with most of your earlier post, for example, narrower baffles have a higher baffle step which compromises LF performance, and need not affect MF/HF design.
I have never, ever, heard a narrow enclosure that sounded real and tactile in the way wider ones with larger drivers do.
Reactions: 2 users
