Big, big TL...
https://www.instagram.com/reel/CnPYhiIqf6B/?igshid=YmMyMTA2M2Y=
this all works (offset driver entry at one third in a quarterwave (1 fourth) pipe where the exit and vent are in the same location or if you really want to exploit it, you fire into a parallel pipe from both ends using the same driver can you put the exit at the ’offset’ at 3x 1 fourth) as downstream ‘1/3’ ,).
It’s all the same. It’s all going for ‘ more‘using the math that allows it and it works every single time and it might be better than anything else because everything else is some sort of weird, distorted, compromise, or flare or taper shape that ultimately is simply another version of awkward?
I don’t know, but these things as perfect rectangles, as if they’re pieces of the inside of a telescope do the same exact thing they just don’t have the lens. Technically, they have instead, super position of wave shapes that land right on top of the next wave shape in exactly the same phase relationship from either side until ultimately, they don’t, which in this case is then at 5X, the fundamental.
Hey, i just found a disturbance in the resonator vortex that will break havoc exponentially on the up/downstream harmonics @1/4 wave of the fundamental and and 1/2 wave from the 3rd harmonic, as stated in the hellmontz/shultz white papers of 1941 ,
that can potentially unload the driver past XMech, destroying the coil in T minus10^9 Newtons,
BUT
unless you use a franken driver with >69 BL.
that design is a coldfusion reactor!
The culprit
those random zeta reticuli smugs spotted by the red arrows.
Reactions: Booger weldz
that mycelium and thc/cbd stylagtites. A few strands seem to influence low frequency response, and tickle the optic nerve, and the inner parts of the ear (same @ brain) into a resonating simultaneously.
once you make the connection that light and sound, are the same exact thing and apply the math to enclosure designs , it’ll becomes simple😝
it explains harmonic sequences(3:1 in particular and ‘ Bells theorum, all of Pythagoras , etc ) , and the relationship between the cone and rod in the optic nerve connection, as well as the Blindspot, and all kinds of things!!
Reactions: maxolini
So your last calculation is the one you will build?
This is what is distracting me at the moment - a possible 6th order series-tuned bandpass alignment for the same driver. I figured out a way to lay out one that comes fairly close to a corresponding Hornresp sim. I haven't "tested" how well the Hornresp bandpass sims match corresponding builds, which is the main reason this is tempting me.
Reactions: GM and Booger weldz
This is confusing me ? How’s it even possible to get those two acoustical lengths to line up to an odd harmonic(3Fb) … so its not terrible and without a smooth uninterrupted band with that doesn’t have a huge hiccup in it In the pressure phase discontinuity and cone flip flop? Some of the cancellation is left over some of the spike is that over excited and 1 million different things happen this area that are really bizarre if you listen to it.
an awkward, expanding path and a very large rear chamber. That’s far too short and really wide, and will have an akward ‘Q’ in the area bandwith that’s already gonna be weird as well.?
im stumped?
