Hi Andrew, Happy New Year!Thanks For your feedback Hans - that is indeed a compliment
OKHi!
Pics of the inside and rear please!! It will help some of the newbie builders to this circuit like crispycircuit above…
Best,
Anand.
Hello GudmundurHi Bonsai,
Happy New Year!
I went through the documentation but I couldn't find in what position of J3 (jumpered or not) I supposed to have standard Miller compensation?
if you leave J3 open it is Miller compensation. If you put the jumper in, it is Transitional Miller Compensation.
Hello Olopollo, I don’t understand your question. Can you explain it again?I have driving problems with KX. Argon Audio SOLO dac is not good for KX and not good preamplifier with OPA2132, not good and B1 buffer. Excellent with motorola G52 and Xiaomi smartphones. Advice for me? Thanks.
Olopollo,
Nice clean looking amp, as a suggestion it is good precaution to insulate your primary wiring. The ground lift suggested by crispycircuit will help a-leave any potential hum issues, and if you read over bonsai’s article on ground loops it may help keep the amp quiet with a little movement on the internal wiring.
Bill
Bill
Good afternoon
I will be very thankful for an answer.
I ask to excuse if before there was an answer in a theme.
as far as is the temperature of transistors of radiator of 70-80С critical warming up in a flow 30-60 minutes ?
what ideas on the temperature of transistors ?
Bonsai
.I will be very thankful for an answer.
HI
I am new on this thread, I would be interrested to build The KX2 and for that would like to know if there are any French builders who have done this amplifier yet. So if you are concerned by my request please let me know, it will be easier for me to have exchanges in french rather than in English.
Sincerly yours
Geo
Sincerly yours
Geo
Apologies for the very late reply here.Good afternoon
Bonsai
70-80C is far too hot. For full class A operation 55-60C is the absolute max upper limit. In your case, I’d operate the amp in class AAB mode.
The damping factor is ~360 at 1 kHz into 8 OhmsBonsai,what is the KX damping factor???
Hi @Gvida,HI
Sincerly yours
Geo
@Bonsai just forwarded your request to me.
As I said to him, I didn't build the KX2 but I built the NX, there may be similarities in the build(?). BTW if I can help I'll, please private message me in french, I'll try to do my best to help.
Thanks,
Raphaël
1. amp in class AAB mode +-28VApologies for the very late reply here.
2. cooling is not little 400мм 150мм 40мм
3. there is a slow warming-up 30 minutes to the temperature 60-70 degrees.
4. thermal balance comes a temperature is a current of rest. current of rest as a mode A class
If you are in class AAB mode and the amplifier ends up settling in class A mode that would normally indicate the heatsinks are undersized, but your heatsinks for class AAB look ok to me given their size. Are the heatsink measurements you give for one channel or both?
I am away travelling at the moment. On Tuesday I will come back to you to take some measurements so we can find your problem.
- New Hifisonix KX2-Amplifier
