C/E/X PA Flat to 30 (FT30) PA TH Awesomeness
If we skip the cone correction wood, it still be playable?
Any design is "playable".
If you skip building the cabinet as Crescendo did, it won't have the same response as he posted.
Reactions: 1 user
Martin (Xoc1) and others had much discussion about "cone correction" or what Tom Danley called a "stub" that he uses in many of his commercial TH designs.
Xoc1 did not include the "V" throat stub in his plans for the TH-18 as it became too much of a clone of the DSL TH-118.
Post #912, 921, 927, 987, etc. and #2343.
https://www.diyaudio.com/community/threads/th-18-flat-to-35hz-xoc1s-design.190635/page-50
Anyway, driver "burn out" or "rocking the cone to death" are different catastrophic failures, thermal or mechanical :) .
Art
Reactions: 1 user
Could I get help calculating the response of this tapped horn using a B&C 18DS115? Does this look correct? It seems wildly uneven and unfortunately I already own two which I cannot replace. Thanks!
OK, not quite sure if I understand since the specs in HR are different from the DS115, but with either specs I see nothing wrong other than its near 3:1 CR is pretty high for such a powerful output driver.
If wanting a more optimal alignment, its specs 'wants' a small ~46 Hz tapped pipe (TP) or horn (TH), which can in theory handle all 3400 W 'fast' transients.
  • 18DS115TH.txt
  • 18DS115TP.txt
Hmm, need to keep in mind that HR doesn't account for any acoustic damping, so in reality its actual response will be somewhat smoother plus a TP, TH is basically a two octave alignment, so you'll need to EQ/XO it above 80-100 Hz, which just leaves some EQing to suit the needs of the app, if any.
In short, had you simmed a typical BR-like flat response it would be severely over-damped (rolled off on both ends of the gain BW), so in the future 'shoot' for ~ +/- 3 dB with equal amplitude peaks.
