Total Domination VFET (TDV) Amp (using 2SK2087C)
2SK77Bs are for losers. 😉
The R3 sinks are small aluminum ones for TO220. They should suffice. I included a little Keratherm on them.
On that note, it might be feasible to mount such power resistors to the big heatsinks. However, that would require drilling into the sinks again. Not pressing my luck there, either, since my last foray put the Tokins so far south they’re wearing shorts and flip flops.
I opted to go with 2.5R 10 Watt chassis-mount resistors for the bias. I originally had paralleled two 4.7R 5W resistors but the current sharing was unequal and resulted in one resistor getting wildly hotter than the other. With 1.4A bias the resistors dissipate about 5W, which is well within the unmounted limits of the new resistors. This is for the 2SK180.
Reactions: ra7
With people paying silly prices for fuses - I just noticed these.
Tin plated copper leads instead of the steel caps and likely steel ends on the holders.
A small thing but easy to implement and should to superior to the typical fuse and holder. Not as easy when they blow - maybe to be inserted after the amplifier is sorted.
The link is to the product page at Mouser https://www.mouser.com/datasheet/2/240/Littelfuse_Fuse_396_Datasheet_pdf-794765.pdf
$1.36 each for ten at a time.
OMG, you just made my day !
The people writing stuff about these fuses are too funny (I’m being polite) see below...
