For Sale CNC MM Phonostage PCBs, kits, modules and power supply
Things you have for sale.
MC phonostage shipped today
Sachin
At last got the time to populate the CNC Phono stage PCB. Faced a huge problem in fighting 50 Hz hum but managed
in the end to almost got rid if it by wrapping the PCB in aluminium foil:
Did then a "Quick&Dirty" frequency response measurement and that looks very good! It matches almost the ideal RIAA curve.
Reactions: 1 user
Just for my convenience I made a small change in the power supply PCB : inserted a 10 Ohm resistance
between the output of the rectifier bridge and the first elco's C5 and C6. With the only purpose to
limit the max. peak current at start up when both C5 and C6 are not charged.
  • OPS-Power-Supply-Forum.pdf
But I also made, again for my own use, a new circuit diagram of the MM pre-amp pcb with the actual component numbers matching those on the
pcb, so .....
Just for my convenience , I have made a circuit diagram from the PCB MM phono part . it is in the attachment.
sachu888, if you see any mistake please let me know and I will correct it.
Joe.
  • CNC-Phono-Pre-Amp-2-Publc..pdf
