DIY F2 clone
Joined 2002
I just finished putting an F2J together. I used a modushop 3U/400 steel chassis. The transformer is an Antek AS-3218 and the bias current is about 2.7A per channel. Part subs were minimal (BC560C instead of ZTX550, R6=10k). I did not test the jfets before hand for gate leakage so I kept R6 relatively low. The trimmers for the channels were adjusted to minimize distortion at about 4W output into 8 ohms @1K Hz.
The PCBs were a generous gift from Twitchie.
Thank you Papa for sharing this design with us Greedy Boyz.
Reactions: 7 users
Lovely!! How does it sound??
Hello guys, changing the subject: I am thinking about experimenting by adding some ribbon tweeters on top of my full rangers, so a new two channels of F2 (kind of) would be nice, but I do not want to burn another 130W or so... so I was wondering about lowering the current, using some "smaller" MOSFETs, much much smaller output caps (so they could form a HP filter with the tweeter impedance), smaller radiators :) Has anyone done something like that before? :frosty:
EDIT: and because it's a current source amp using the same amp with the ribbon... not sure if Mr. Kirchhoff would be on my side...
